Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Virtual Explorer going crazy
Old 05-14-2009   #1 (permalink)
Vincent Fatica
I haven't been with VPC long. Host = XPProSP3, Guest = VistaUltimate,
additions installed. I export my "Apps" drive as the guest's Z:. If,
in the guest, I roam around that drive long enough (usually under a
minute) digging 2 or 3 levels into folders, inevitably, the guest's
Explorer goes crazy, using 99% CPU (according to the guest's TaskMgr).
The host is at 50% CPU. If I continue, most of the time the guest's
Explorer just restarts, unceremoniously; occasionally I get a message
box saying that Explorer "has stopped working" and prompting me to
restart it. Details show APPCRASH at offset 65A20 in NTDLL.DLL. Any
ideas? Thanks.
- Vince
Old 05-14-2009   #2 (permalink)
Jane C
Re: Virtual Explorer going crazy
> ideas? Thanks.
> - Vince
Shared folders have never worked that well in VPC. Use standard
networking shares instead.
Jane, not plain 64 bit enabled :-)
Batteries not included. Braincell on vacation ;-)
MVP - Windows Desktop Experience 2007-2009
Old 05-14-2009   #3 (permalink)
Vincent Fatica
On Fri, 15 May 2009 07:25:39 +1000, Jane C
Please give me an idea how to do that. Now I'm using NAT. I have two
NICs on the host, one internet (DHCP) the other LAN.
Old 05-14-2009   #4 (permalink)
Mark Rae [MVP]
"Vincent Fatica" <abuse@xxxxxx> wrote in message
newss9p05l20vo68bm0pm6ofqlbottike8vcc@xxxxxx
As Jane says, this is standard networking and, as such, nothing to do with
Virtual PC per se...
Share a folder on the host and then map a drive to it from the guest like
you would with any two physical machines on the same network...
Mark Rae
ASP.NET MVP
http://www.markrae.net
Old 05-14-2009   #5 (permalink)
Vincent Fatica
On Fri, 15 May 2009 00:33:58 +0100, "Mark Rae [MVP]"
What "same network" are they on? The internet interface does not bind
the "Server" service.
Old 05-14-2009   #6 (permalink)
Mark Rae [MVP]
news:bgbp05t3nq5aak779a6h3ucjl5pqfpsjj8@xxxxxx
Whatever one you add them to - this is not a Virtual PC issue per se...
If you had two physical machines and wanted them to communicate, how would
you do it?
It's the same with one virtual machine and one physical machine, or two
virtual machines...
Mark Rae
ASP.NET MVP
Old 05-14-2009   #7 (permalink)
Vincent Fatica
On Fri, 15 May 2009 01:01:32 +0100, "Mark Rae [MVP]"
>you do it?
>virtual machines...
Well, I couldn't do it "over the internet" because that interface
doesn't run "Server". But (to my surprise) I simply did "net use ..."
specifying the host's LAN IP and it worked.
My Explorer just went Crazy *HELP* General Discussion
error: Virtual PC could not open the Virtual Machine Network Servicesdriver Virtual PC
Vista Home Premium .. Can't install Virtual Server.. so how do Iautomatically start a Virtual PC without a login? Virtual PC
How To: Windows Performance Monitor Virtual Switch Port instance IDto Virtual NIC or VM Virtual Server
Vista's explorer drives me crazy Vista General
