| | Again "The Virtual Machine Monitor Driver required is missing" Hi,everyone I have met the "The Virtual Machine Monitor Driver required is missing" error after a mysterious system clash.When I uninstall the installer stopped and said "Some files of the application is used by the Windows Explorer(Not Internet Explorer)", I can continue uninstalling whether by ignore that or by end the Explorer Process use the Taskmanager. But the VPC dosn't work when I finished the new installation again with the same error. I came here and found some similar problem reported but no useful answer. Anyone shall help me? My system is Vista Ultimate with SP1 which was update installed from XP SP.3. The "mysterious system clash" of host has happened the day before yesterday. I shutted down the system normal after using a VM machine, but when I switched on next the partition table has gone.I have tried a lot and gotten it back finally,And "repairred the system "with the installation disc, then got the system started, tried to start the VPC, and then the error appeared. |
| | Re: Again "The Virtual Machine Monitor Driver required is missing" On 5ÔÂ16ÈÕ, ÏÂÎç11ʱ52·Ö, taoeugon2...@xxxxxx: It is seemed no one want to answer me hemm? There's a special I found in this case: When you uninstall the damned application the VMM.sys will stay.Is it meens there are something using it still, say: Microsoft Device Emulator or somewhat? |
| | Re: Again "The Virtual Machine Monitor Driver required is missing" On 5ÔÂ17ÈÕ, ÏÂÎç8ʱ32·Ö, taoeugon2...@xxxxxx wrote: Quote: > On 5ÔÂ16ÈÕ, ÏÂÎç11ʱ52·Ö, taoeugon2...@xxxxxx wrote: > It is seemed no one want to answer me hemm? > There's a special I found in this case: When you uninstall the damned > application the VMM.sys will stay.Is it meens there are something > using it still, say: Microsoft Device Emulator or somewhat? run the VirtualPC as administrator even if you logon used a admistrator account. |
| During install "required CD/DVD drive device driver missing" | Vista installation & setup | |||
| What does "password not required" flag means to a machine ? | PowerShell | |||
| Build 5744 still "A required CD/DVD drive device is missing" since beta 2 !!! | Vista installation & setup | |||
| "Required driver could not be installed" message preventing beta 2 | Vista installation & setup | |||
| Build 5728 still "A required CD/DVD drive device is missing" | Vista installation & setup | |||
