| vista ultimate x64 | problem i m getting this kind of icon in some setups..wht will be the issue??/ |
| | Re: problem This does not appear to be related to Virtual PC. Please ask in one of the general Windows newsgroups. Cheers, Benjamin Armstrong =========================== Senior Program Manager Lead Windows Virtualization Blog: http://blogs.msdn.com/Virtual_PC_Guy Book: http://tinyurl.com/ysxcbm This posting is provided "AS IS" with no warranties, and confers no rights. You assume all risk for your use. amit22 wrote: Quote: > i m getting this kind of icon in some setups..wht will be the issue??/ > > > +-------------------------------------------------------------------+ > |Filename: Untitled.jpg | > |Download: http://www.vistax64.com/attachment.p...hmentid=13801| > +-------------------------------------------------------------------+ > |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
