| Guest | Mouse Wheel in VirtualPC Does Not Work I have recently upgraded my Dell D620 Latitude laptop from WinXP Pro (32-bit) to Windows 7 RC (64-bit). I have a number of VirtualPC 2007 images that I use for testing on various platforms and looking at beta software. I have installed the 64-bit version of VirtualPC SP1. The images all work with the exception of the mouse wheel within the virtual machine. I have tried this out with WinXP Pro, Windows 7 RC, and Windows Server 2008 images. All are 32-bit and all exhibit the same behavior: a gentle rotation of the wheel does nothing; a quick rotation of the wheel sometimes gets a scroll and sometimes not. I regard this behavior as unusable as I tend to use the mouse wheel a lot. All of this worked just fine on WinXP. I have re-installed the Virtual Machine Additions on all of the machines. The Windows 7 RC virtual image was created after the upgrade to Windows 7 and the installation of the 64-bit version of VirtualPC (just to isolate the possibility that I had corrupted the images during the transition); the only software other than the 32-bit Widnows 7 RC are the virtual machine additions. The behavior of the mouse scroll wheel is the same as the other guest systems that I have tested. I have googled, binged, and yahoo-ed. There are scattered mentions of this problem (dating back to VPC 2004) but no solutions. I am aware that I could start up one of these images and then use remote desktop connections to get access to that image. I, in fact, do just that for some development that I am doing; the mouse works just fine. This is acceptable in this case because I spend hours at a time in the development VM. These test environments are different in that I will bring up an image for just a short time: minutes rather than hours. Adding the rdc step is much more significant in these cases. Does anyone have any idea of what to do next to get the scroll wheel to work? -- Jon Stonecash |
| Guest | Re: Mouse Wheel in VirtualPC Does Not Work Have you changed any of the default mouse sensitivity in the host or the virtual machine? Cheers, Benjamin Armstrong =========================== Senior Program Manager Lead Windows Virtualization Blog: http://blogs.msdn.com/Virtual_PC_Guy Book: http://tinyurl.com/ysxcbm This posting is provided "AS IS" with no warranties, and confers no rights. You assume all risk for your use. JonStonecash wrote: Quote: > I have recently upgraded my Dell D620 Latitude laptop from WinXP Pro (32-bit) > to Windows 7 RC (64-bit). I have a number of VirtualPC 2007 images that I use > for testing on various platforms and looking at beta software. I have > installed the 64-bit version of VirtualPC SP1. The images all work with the > exception of the mouse wheel within the virtual machine. I have tried this > out with WinXP Pro, Windows 7 RC, and Windows Server 2008 images. All are > 32-bit and all exhibit the same behavior: a gentle rotation of the wheel does > nothing; a quick rotation of the wheel sometimes gets a scroll and sometimes > not. I regard this behavior as unusable as I tend to use the mouse wheel a > lot. > > All of this worked just fine on WinXP. I have re-installed the Virtual > Machine Additions on all of the machines. The Windows 7 RC virtual image was > created after the upgrade to Windows 7 and the installation of the 64-bit > version of VirtualPC (just to isolate the possibility that I had corrupted > the images during the transition); the only software other than the 32-bit > Widnows 7 RC are the virtual machine additions. The behavior of the mouse > scroll wheel is the same as the other guest systems that I have tested. > > I have googled, binged, and yahoo-ed. There are scattered mentions of this > problem (dating back to VPC 2004) but no solutions. > > I am aware that I could start up one of these images and then use remote > desktop connections to get access to that image. I, in fact, do just that for > some development that I am doing; the mouse works just fine. This is > acceptable in this case because I spend hours at a time in the development > VM. These test environments are different in that I will bring up an image > for just a short time: minutes rather than hours. Adding the rdc step is much > more significant in these cases. > > Does anyone have any idea of what to do next to get the scroll wheel to work? > |
| Guest | Re: Mouse Wheel in VirtualPC Does Not Work I have changed the mouse sensitivity in the guest Windows 7 system: there has been no apparent effect: both ways have essential no scroll wheel functionality. I have not changed the mouse sensitivity in the host 64-bit Windows 7 system. that than the fact that I have installed the drivers for the Microsoft Comfort Optical Mouse 3000 (Vista 64-bit driver from the Microsoft site), this is a fairly clean install. -- Jon Stonecash "Benjamin Armstrong [MSFT]" wrote: Quote: > Have you changed any of the default mouse sensitivity in the host or the > virtual machine? > > Cheers, > Benjamin Armstrong > =========================== > Senior Program Manager Lead > Windows Virtualization > > Blog: http://blogs.msdn.com/Virtual_PC_Guy > Book: http://tinyurl.com/ysxcbm > > This posting is provided "AS IS" with no warranties, and confers no > rights. You assume all risk for your use. > > JonStonecash wrote: Quote: > > I have recently upgraded my Dell D620 Latitude laptop from WinXP Pro (32-bit) > > to Windows 7 RC (64-bit). I have a number of VirtualPC 2007 images that I use > > for testing on various platforms and looking at beta software. I have > > installed the 64-bit version of VirtualPC SP1. The images all work with the > > exception of the mouse wheel within the virtual machine. I have tried this > > out with WinXP Pro, Windows 7 RC, and Windows Server 2008 images. All are > > 32-bit and all exhibit the same behavior: a gentle rotation of the wheel does > > nothing; a quick rotation of the wheel sometimes gets a scroll and sometimes > > not. I regard this behavior as unusable as I tend to use the mouse wheel a > > lot. > > > > All of this worked just fine on WinXP. I have re-installed the Virtual > > Machine Additions on all of the machines. The Windows 7 RC virtual image was > > created after the upgrade to Windows 7 and the installation of the 64-bit > > version of VirtualPC (just to isolate the possibility that I had corrupted > > the images during the transition); the only software other than the 32-bit > > Widnows 7 RC are the virtual machine additions. The behavior of the mouse > > scroll wheel is the same as the other guest systems that I have tested. > > > > I have googled, binged, and yahoo-ed. There are scattered mentions of this > > problem (dating back to VPC 2004) but no solutions. > > > > I am aware that I could start up one of these images and then use remote > > desktop connections to get access to that image. I, in fact, do just that for > > some development that I am doing; the mouse works just fine. This is > > acceptable in this case because I spend hours at a time in the development > > VM. These test environments are different in that I will bring up an image > > for just a short time: minutes rather than hours. Adding the rdc step is much > > more significant in these cases. > > > > Does anyone have any idea of what to do next to get the scroll wheel to work? > > |
| Guest | RE: Mouse Wheel in VirtualPC Does Not Work I have the same problem with Virtual PC 2007 in Vista 64. I have 3 mice on the PC. 2 of them work OK(wired Logitech mouse and wireless Logitech trackball) and one has the problem (Microsoft Wireless Laser Mouse 7000). This suggests it has something to do with interaction with the host mouse driver. "JonStonecash" wrote: Quote: > I have recently upgraded my Dell D620 Latitude laptop from WinXP Pro (32-bit) > to Windows 7 RC (64-bit). I have a number of VirtualPC 2007 images that I use > for testing on various platforms and looking at beta software. I have > installed the 64-bit version of VirtualPC SP1. The images all work with the > exception of the mouse wheel within the virtual machine. I have tried this > out with WinXP Pro, Windows 7 RC, and Windows Server 2008 images. All are > 32-bit and all exhibit the same behavior: a gentle rotation of the wheel does > nothing; a quick rotation of the wheel sometimes gets a scroll and sometimes > not. I regard this behavior as unusable as I tend to use the mouse wheel a > lot. > > All of this worked just fine on WinXP. I have re-installed the Virtual > Machine Additions on all of the machines. The Windows 7 RC virtual image was > created after the upgrade to Windows 7 and the installation of the 64-bit > version of VirtualPC (just to isolate the possibility that I had corrupted > the images during the transition); the only software other than the 32-bit > Widnows 7 RC are the virtual machine additions. The behavior of the mouse > scroll wheel is the same as the other guest systems that I have tested. > > I have googled, binged, and yahoo-ed. There are scattered mentions of this > problem (dating back to VPC 2004) but no solutions. > > I am aware that I could start up one of these images and then use remote > desktop connections to get access to that image. I, in fact, do just that for > some development that I am doing; the mouse works just fine. This is > acceptable in this case because I spend hours at a time in the development > VM. These test environments are different in that I will bring up an image > for just a short time: minutes rather than hours. Adding the rdc step is much > more significant in these cases. > > Does anyone have any idea of what to do next to get the scroll wheel to work? > > -- > Jon Stonecash |
| Guest | Re: Mouse Wheel in VirtualPC Does Not Work Quote: Quote: > > Does anyone have any idea of what to do next to get the scroll wheel to > > work? Synaptics Pointing Device and put its icon in the system tray on my 32bit XP, but failed to do this for XP 64bit. OS's on separate removable drives. So it may be a 64bit driver related problem, I've had a lot of irritating bugs running XP 64bit, and ditched Vista 64bit Ultimate a few days after installing it. Ran like a dog with Intel Extreme processor and 4GB Crucial, an an Asus mobo. Plus virtually no support for existing peripherals. |
| RE: Mouse hesitations with VirtualPC 2007 | Virtual PC | |||
| Mouse Wheel | Virtual PC | |||
| mouse wheel no work in ie7 when run as administrator | Vista General | |||
| Mouse Wheel dont work in games | Vista Games | |||
| Mouse Drivers MS Optical Wheel Mouse -- Vista Beta 2 64-bit | Vista hardware & devices | |||
