Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Guest Machine not booting
Old 07-25-2009   #1 (permalink)
Vista Home Premium x64
I transferred two vhd's over to my new computer, currently running Vista Home Premium x64. Both guest machines are running XP Professional.
One boots without any issues. The other machine stays at the Windows XP screen without ever going into Windows or encountering any errors. I can boot into safe mode successfully on that machine.
Any idea how to remedy this situation? I know that Vista Home Premium is unsupported with Virtual PC 2007, but hoping there is a way to recover this machine successfully.
Thoughts?
Old 07-25-2009   #2 (permalink)
Steve Jain [MVP]
Re: Guest Machine not booting
On Sat, 25 Jul 2009 13:11:03 -0500, DigitalFool
>Thoughts?
There's a hotfix for VPC2007sp1 that includes Vista Home as a
supported host. I just posted the KB related to it on another thread.
When you boot into safe mode, try removing the VM Additions and
restarting.
Cheers,
Steve Jain, Virtual Machine MVP
http://vpc.essjae.com/
Old 07-25-2009   #3 (permalink)
When I try and install the hotfix rollup KB958162, I get this msg:
'The upgrade patch cannot be installed by the Windows Installer service because the program to be upgraded may be missing, or the upgrade patch may update a different version of the program to be upgraded exists on your computer and that you have the correct upgrade patch.'
The file version Virtual PC.exe is 6.0.156.0 dated 2/18/2007.
Any thoughts?
Old 07-25-2009   #4 (permalink)
Steve Jain [MVP]
On Sat, 25 Jul 2009 21:29:22 -0500, DigitalFool
>Any thoughts?
You need to apply SP1 first, then the hotfix.
Cheers,
Old 08-08-2009   #5 (permalink)
David Wilkinson
I think VPC 2007 SP1 is version 6.0.192.0. You need to have that first.
David Wilkinson
Visual C++ MVP
Share VPN with guest machine? Virtual PC
My guest machine in hyper-V has conectivity but the host has not. Virtual Server
Cant ping virtual server guests from the host machine; VS guest cr Virtual Server
Old XP moved as guest to new Vista Host Machine Software
Booting my XP machine from a mapped drive on my vista machine Vista networking & sharing
