Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Switch to 64 bit - will it work?
Old 08-08-2009   #1 (permalink)
Jan Eliasen
Hi all
I have currently Windows XP 32bit with Virtual PC 2007SP1 installed. I
have lots of virtual machines.
Now, I want to install Widwos 7 64 bit and the 64 bit version of
virtual PC. Can I use my virtual machines without troubles?
Thanks!
eliasen, representing himself and not the company he works for.
Private blog: http://blog.eliasen.dk
Private email: jan@xxxxxx
Old 08-08-2009   #2 (permalink)
Bill Grant
Re: Switch to 64 bit - will it work?
"Jan Eliasen" <eliasen@xxxxxx> wrote in message
newsflr75l3vqpbkjgkh9qsg0fn3qi925q22f@xxxxxx
Quote:
> Hi all
> Thanks!
I would not try to move the virtual machines over. I would remove the
vmAdditions and shut the machines down.
You should be able to create new vms using the existing .vhd files under
the new OS and VPC version.
Old 08-08-2009   #3 (permalink)
Mark Rae [MVP]
Quote:
> I have currently Windows XP 32-bit with Virtual PC 2007SP1 installed. I
> Now, I want to install Windows 7 64-bit and the 64-bit version of
Yes.
FYI, the 64-bit "version" of VPC 2007 isn't actually a 64-bit app:
http://vpc.visualwin.com/ngfaq.aspx#18
Mark Rae
ASP.NET MVP
http://www.markrae.net
Old 08-09-2009   #4 (permalink)
Bill Grant
"Mark Rae [MVP]" <mark@xxxxxx> wrote in message
news:ucmnEzHGKHA.4608@xxxxxx
> Yes.
> Mark Rae
> ASP.NET MVP
The OP may be referring to the Win 7 version of VPC. The RC version of
the beta is now available.
Old 08-09-2009   #5 (permalink)
David Wilkinson
Jan Eliasen wrote:
Quote:
> Hi all
> Thanks!
I have a dual boot XP x86 and Vista x64 machine and I am able to rum the same
virtual machines in both of them (using Virtual PC 2007 SP1 installed on both
machines). And soon I am planning to replace the Vista machine with Windows 7,
and am expecting/hoping the virtual machines will still work.
David Wilkinson
Visual C++ MVP
Old 08-09-2009   #6 (permalink)
Robert Comer
They do, but (<g>) you can't use any of the new features in Windows
Virtual PC.
To run them in both, just leave the VPC additions installed from
VPC2007 and to add them to the Win7 VPC, just double click on the .vmc
file and it'll add it to the virtual machines folder and start it up.
Do not install the integration components, just leave the VPC
additions installed.
It'd actually be better to convert them to the new VPC rather than
running it in both if it's XPSP3 or above, but I can understand the
need for compatibility between the versions, I need the same myself
and it works fine. You just have to use shared network drives instead
of shared folders.
To convert them, uninstall the VPC additions while in VPC2007, then
boot to win 7 and double click on the .vmc to add and start the VM,
and when it's fully booted, install the integration components. (if
XPSP3 or above)
Bob Comer
On Sun, 09 Aug 2009 06:50:41 -0400, David Wilkinson
<no-reply@xxxxxx> wrote:
Quote:
>Jan Eliasen wrote:
Quote:
>> Hi all
>> Thanks!
Old 08-09-2009   #7 (permalink)
David Wilkinson
> Virtual PC.
> of shared folders.
> XPSP3 or above)
Robert:
Good information, but on this machine I will be running VPC 2007 on Windows 7,
because the machine does not have hardware virtualization.
David Wilkinson
Visual C++ MVP
Old 08-09-2009   #8 (permalink)
Robert Comer
Then I wouldn't worry, but I really wouldn't chance saved states or
undo disks between the 2 OS's. It may work, but it may hose it too.
Bob Comer
On Sun, 09 Aug 2009 15:36:06 -0400, David Wilkinson
>> Virtual PC.
>> of shared folders.
>> XPSP3 or above)
>Robert:
User switch doesn’t work on Windows Vista Virtual PC
Why cant i switch them off ???????????????? Vista mail
KVM Switch does not work in the Vista? Vista General
Anyway to switch from Work network setting to Home? Vista General
Known bug? arbitrary switch options work. PowerShell
