Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Sound Error
Old 08-14-2009   #1 (permalink)
jslow
Sound Error
I installed Microsoft's Virtual PC 2007, SP1 and then installed Windows 7 RC
on the VM.
I am getting an x with a red background on it on the speaker icon in the
lower right hand corner. When I put the mouse pointer on the speaker icon, I
get the following message: "No Audio Device is Installed".
What does this mean? Is there a way to correct it?
Thanks
Dell Vostro 420, WinXP SP3 Pro, Intel Core 2 Quad Q8200 Processor, 500 Gig
HD, 80 Gig Ext USB 2 HD, 3 GB RAM, IE7 & OE 6, NSW 2008 Premium, Norton
Anti-Virus 2009, Ad-Aware 2008, Spybot-S & D1.6.2,ZA
Old 08-14-2009   #2 (permalink)
Robert Comer
Re: Sound Error
When you first set up the VM, did you select Vista as the host OS in the
virtual machine wizard? You need to do that.
You don't need to reinstall Win7, just create a new VM and attach the old
hard drive to it, than when the new VM is created, uninstall the VM
Additions, and then reinstall them, or just install them if you haven't done
that before.
Bob Comer
"jslow" <jslow@xxxxxx> wrote in message
news44D53AF-C6BA-4363-BC35-A302C09003D4@xxxxxx
Quote:
> Hi,
> RC
> on the VM.
> I
> Thanks
Old 08-14-2009   #3 (permalink)
jslow
Re: Sound Error
Hi Bob,
Thanks for the reply.
I don't have Vista installed.
I purchased a Dell Vostro computer that was downgraded to Windows XP, SP3
and thats the operating system I've been using.
Do I need to have Vista installed for Windows 7 RC to run properly in
Virtual PC?
Everything else seems to be operating OK with Windows 7 RC installed on the
Virtual PC.
Thanks,
jslow
> that before.
> Bob Comer
Quote:
> > Hi,
> > RC
> > on the VM.
> > I
> > Thanks
Old 08-14-2009   #4 (permalink)
Robert Comer
Re: Sound Error
Quote:
>Virtual PC?
That's not what I meant, I just meant that when you set up the VM for
Windows 7 in VPC, you should select "Vista" as the OS choice in the
VPC wizard, that sets up things to be more compatible with Win7.
Bob Comer
On Fri, 14 Aug 2009 12:59:01 -0700, jslow
<jslow@xxxxxx> wrote:
Quote:
>Hi Bob,
>Virtual PC?
>Virtual PC.
>Thanks,
>jslow
Old 08-16-2009   #5 (permalink)
jslow
Re: Sound Error
Hi Bob,
I followed your suggestions and I now have sound on Windows 7 RC in the
Virtual PC.
Thanks,
John
Quote:
> >Virtual PC?
> Bob Comer
Quote:
> >Hi Bob,
> >Virtual PC?
> >Virtual PC.
> >Thanks,
> >jslow
Old 08-16-2009   #6 (permalink)
Robert Comer
Re: Sound Error
Cool, good to hear.
Bob Comer
On Sun, 16 Aug 2009 15:57:01 -0700, jslow
Quote:
>Hi Bob,
>Virtual PC.
>Thanks,
>John
Cant install sound drivers, NTVDM error Sound & Audio
Does this sound like a graphics card error? Graphic cards
Rundll32.exe error = No Sound! Sound & Audio
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Vista General
Direct Sound Output V2.43 (d) error Vista music pictures video
