| | Connecting to VPC 2007 trought Remote Desktop Connection Hello. I have a small home network connected like this: Computer A - Wired Connection to a router Laptop B - Wireless Connection from router Virtual Machine C - Running on Laptop B VM C has internet connection trough network adapter Broadcom 802.11b/g WLan and I have checked "Enable Remote Desktop on this computer" in System Properties > Remote tab. I can access internet in the VM C. I want to access to VM C from Computer A trough Remote Desktop Connection but it cannot communicate with it. I cannot ping it also from Computer A. I would like to know what is the possible explanation to this since I'm not using NAT (ipconfig -> 192.168.2.10). Regards |
| | Re: Connecting to VPC 2007 trought Remote Desktop Connection On Wed, 9 Sep 2009 07:16:02 -0700, PedroSBB <PedroSBB@xxxxxx> wrote: Quote: >Hello. I have a small home network connected like this: > >Computer A - Wired Connection to a router >Laptop B - Wireless Connection from router >Virtual Machine C - Running on Laptop B > >VM C has internet connection trough network adapter Broadcom 802.11b/g WLan >and I have checked "Enable Remote Desktop on this computer" in System >Properties > Remote tab. I can access internet in the VM C. >I want to access to VM C from Computer A trough Remote Desktop Connection >but it cannot communicate with it. I cannot ping it also from Computer A. >I would like to know what is the possible explanation to this since I'm not >using NAT (ipconfig -> 192.168.2.10). > >Regards disabling the firewall on the VM and see if you can ping and get remote access. If you can, then you just need to configure your firewall. -- Cheers, Steve Jain, Virtual Machine MVP http://vpc.essjae.com/ |
| invalid connection file on remote desktop connection | Vista General | |||
| Fixed! Remote Desktop Connection (RDC) SLOW/NO Connection Issue | Vista networking & sharing | |||
| Can't login to remote comp. using Remote Desktop Connection on Vis | Vista account administration | |||
| Remote Desktop unavailable on lan after connecting to wireless? | Vista General | |||
| remote desktop connecting???? | Vista networking & sharing | |||
