| | VPC 2007 SP1 problems with Visual Studio 6 Hi all, I am running VPC 2007 SP1 on Windows XP SP3 so that I can continue to support very old applications that are being migrated to newer technology. The Guest OS is Windows ME and I have installed Visual Studio 6 with all services packs and also the platform SDK. The problem I am having is that when I try and execute cl.exe from the command prompt eg cl /? it freezes. Using Ctrl-Alt-Del to bring up task manager but NOT cancelling any process and then switching back to the command prompt unlocks the command and the options appear. I should point out that I have a "real" machince here that is setup almost identically which works fine but I want to get rid of that machine. So its definately something to do with VPC 2007. Has anyone else seen this before or can direct me to any suggestions to resolve this issue ? Thanks Leslie. |
| | Re: VPC 2007 SP1 problems with Visual Studio 6 Leslie Milburn wrote: Quote: > Hi all, > > I am running VPC 2007 SP1 on Windows XP SP3 so that I can continue to > support very old applications that are being migrated to newer technology. > The Guest OS is Windows ME and I have installed Visual Studio 6 with all > services packs and also the platform SDK. > > The problem I am having is that when I try and execute cl.exe from the > command prompt eg cl /? it freezes. Using Ctrl-Alt-Del to bring up task > manager but NOT cancelling any process and then switching back to the > command prompt unlocks the command and the options appear. > > I should point out that I have a "real" machince here that is setup almost > identically which works fine but I want to get rid of that machine. So its > definately something to do with VPC 2007. > > Has anyone else seen this before or can direct me to any suggestions to > resolve this issue ? environment for VC6, I would use Windows XP, not ME. -- David Wilkinson Visual C++ MVP |
| | Re: VPC 2007 SP1 problems with Visual Studio 6 "David Wilkinson" <no-reply@newsgroup> wrote in message news:OfU4kDeOKHA.1280@newsgroup Quote: > Leslie Milburn wrote: Quote: >> Hi all, >> >> I am running VPC 2007 SP1 on Windows XP SP3 so that I can continue to >> support very old applications that are being migrated to newer >> technology. >> The Guest OS is Windows ME and I have installed Visual Studio 6 with all >> services packs and also the platform SDK. >> >> The problem I am having is that when I try and execute cl.exe from the >> command prompt eg cl /? it freezes. Using Ctrl-Alt-Del to bring up task >> manager but NOT cancelling any process and then switching back to the >> command prompt unlocks the command and the options appear. >> >> I should point out that I have a "real" machince here that is setup >> almost >> identically which works fine but I want to get rid of that machine. So >> its >> definately something to do with VPC 2007. >> >> Has anyone else seen this before or can direct me to any suggestions to >> resolve this issue ? > Not an answer to your question, but if I were going to set up a virtual > environment for VC6, I would use Windows XP, not ME. > Yes you are right and we tried that but to no avail. I suspect this was because XP does not have a true DOS command prompt. Thanks anyway Leslie. |
| | Re: VPC 2007 SP1 problems with Visual Studio 6 "Leslie Milburn" <CDB4W@newsgroup> wrote in message news:uPhVJ%23eOKHA.1280@newsgroup Quote: > I suspect this was because XP does not have a true DOS command prompt. -- Mark Rae ASP.NET MVP http://www.markrae.net |
| | Re: VPC 2007 SP1 problems with Visual Studio 6 "Mark Rae [MVP]" <mark@newsgroup> wrote in message news:%23hQMZKlOKHA.3724@newsgroup Quote: > "Leslie Milburn" <CDB4W@newsgroup> wrote in message > news:uPhVJ%23eOKHA.1280@newsgroup > Quote: >> I suspect this was because XP does not have a true DOS command prompt. > Highly unlikely... > > > -- > Mark Rae > ASP.NET MVP > http://www.markrae.net stuff that is no longer available. This does not work under XP cmd prompt at all and we suspect (have virtually confirmed) it is because it makes low level DOS interrupt calls as part of its processing. This has worked without fail under Windows ME way back to Windows For Workgroups 3.11 - this is real legacy stuff we are talking about here. So our approach was to hopefully run ME under Virtual PC but this time it is Visual Studio cl.exe which locks up - the other stuff builds fine which is pleasing. I am now investigating other virtualisation products to see if they perform better. I will report back here with the results. Thanks Leslie |
| | #6 (permalink) |
| | Re: VPC 2007 SP1 problems with Visual Studio 6 "Bob Campbell" <bob@newsgroup> wrote in message news:qK2dnbKvEvNnIyvXnZ2dnUVZ_qydnZ2d@newsgroup Quote: > "Leslie Milburn" <CDB4W@newsgroup> wrote in message > news:OO7nLd5NKHA.220@newsgroup > Quote: >> The problem I am having is that when I try and execute cl.exe from the >> command prompt eg cl /? it freezes. Using Ctrl-Alt-Del to bring up task >> manager but NOT cancelling any process and then switching back to the >> command prompt unlocks the command and the options appear. > I do this all the time, but in XP. Visual Studio 6 in VPC SP1 on XP runs > fine. We cannot use XP as the guest OS for other reasons. A 16 bit OS is a requirement for this legacy stuff we are trying to keep going until early new year when the replacement appliaction goes live. So if worse comes to worse I will reinstall Me as the main OS and live with it for the next few months but this was a good excuse I guess to play around with VPC and get paid for it. Thanks Leslie. |
| Visual Studio | Vista General | |||
| Err.Number 486, Vista Ultimate, Visual Studio, & Visual Basic | Vista General | |||
| Re: Visual Studio | Vista General | |||
| visual studio and asp | Vista security | |||
| Visual Studio 6 and Visual Source Safe 6 on Vista | Vista General | |||
