Go Back   Vista Forums > Misc Newsgroups > Virtual PC
Vista - Creating an Virtual network using Virtual pc
Old 10-16-2009   #1 (permalink)
Vijay
I'm using windows server 2008 and I'm new to it. I would like to use the
windows server as a host and create a network of some client machines as
clients(Windows xp, Vista etc) and like to study about the group policy
etc... Can anyone tell me where I find the learning resources and demos.
Thanks and Regards,
Vijay chandar
Old 10-17-2009   #2 (permalink)
Mark Rae [MVP]
Re: Creating an Virtual network using Virtual pc
"Vijay" <vijaychandar1989@newsgroup> wrote in message
news:9433551F-7112-4DC7-8101-EDF3D96927B7@newsgroup
http://tinyurl.com/yz7akb5
This has nothing to do with Virtual PC...
Mark Rae
ASP.NET MVP
http://www.markrae.net
Old 10-17-2009   #3 (permalink)
Vijay
I think I've put the question in the wrong way. My question is how to create
a network using virtual machines having a host machine as the host operating
system and clients as the virtual machines.
Thanks and Regards,
Vijay chandar
"Mark Rae [MVP]" <mark@newsgroup> wrote in message
news:u9eXj5tTKHA.4408@newsgroup
> Mark Rae
> ASP.NET MVP
Old 10-17-2009   #4 (permalink)
Mark Rae [MVP]
news:uTZwoYyTKHA.1792@newsgroup
[please don't top-post]
http://www.caliburn.nl/topposting.html
> create a network using virtual machines having a host machine as the host
> operating system and clients as the virtual machines.
You create a network using virtual machine in *EXACTLY* the same way as you
create a network using physical machines - there is no difference.
This still has nothing to do with Virtual PC...
Mark Rae
ASP.NET MVP
Old 10-17-2009   #5 (permalink)
Bill Grant
news:#sMa$qyTKHA.508@newsgroup
Quote:
>>>> the windows server as a host and create a network of some client
>>>> machines as clients(Windows xp, Vista etc) and like to study about the
>>>> group policy etc... Can anyone tell me where I find the learning
> you create a network using physical machines - there is no difference.
> Mark Rae
> ASP.NET MVP
Old 10-17-2009   #6 (permalink)
Bill Grant
> Mark Rae
> ASP.NET MVP
As Mark pointed out, this really is a networking problem, not a virtual
machine problem. What sort of virtualization are you running on this server?
As a general rule I would not recommend running the host as a domain
controller, whatever system you use.
Old 10-18-2009   #7 (permalink)
Poutnik
In article <#sMa$qyTKHA.508@newsgroup>,
mark@newsgroup says...
Unless he uses VPC for clients
and is going to configure virtual adapters.
Poutnik
The best depends on how the best is defined.
Old 10-18-2009   #8 (permalink)
Steve Jain [MVP]
But you configure a "virtual" NIC in a VM the same way you configure a
"real" NIC on a physical PC.
Cheers,
Steve Jain, Virtual Machine MVP
http://vpc.essjae.com/
http://smudj.wordpress.com/
Old 10-18-2009   #9 (permalink)
Steve Jain [MVP]
On Fri, 16 Oct 2009 21:42:19 +0530, "Vijay"
<vijaychandar1989@newsgroup> wrote:
Quote:
>Hi,
What VM program are you using? Hyper-V, Virtual Server, etc?
What do you mean "create a network"? Do you mean a separate "virtual"
network isolated from the host's network? Or, are you just wanting to
set up a bunch of VMs on the existing network?
Cheers,
Old 10-18-2009   #10 (permalink)
Bo Berglund
On Sun, 18 Oct 2009 14:00:34 +0200, Poutnik <me@newsgroup> wrote:
Quote:
>In article <0rgld55trgcpdut471r8dpvcch4r569gqa@newsgroup>, noreply.-
>@-.essjae.com says...
>But virtual NICs configuration has usually extra settings,
>not present in real NIC ones, so OP could get confused.
There are *no* extra settings inside the virtual machines.
The default setting of VPC2007 is to use the host's own NIC for the
NIC in the new guest and with this the OP will have to do *nothing* in
the guest after installing a Windows operating system there. Windows
will discover the network adapter, install the proper driver and set
up the network connection to use DHCP (Automatic) address retrieval.
There is absolutely nothing special about this compared to the same
scenario in a physically separate PC.
Don't confuse him by saying otherwise. He will be good to go using the
defaults.
Bo Berglund (Sweden)
Re: Hyper-V, Virtual Network, Virtual Switch - Test Machine Virtual Server
error: Virtual PC could not open the Virtual Machine Network Servicesdriver Virtual PC
About creating a virtual test network Virtual PC
RE: Virtual PC could not open the Virtual Machine Network Services driver Virtual PC
Re: Virtual Server 2005 R2 - Virtual Network Virtual Server
