Karl E. Peterson was thinking very hard :
> I just noticed today that the copy of FrontPage 2003 I installed in an XP
> Mode VM is restricted to the primary monitor (#1) on a dual-monitor system.
> If I try dragging it over to the secondary (#2) monitor, it just disappears
> off the edge never appearing at all on #2, and the drag is stopped when the
> cursor hits the edge of #1. Using a utility like UltraMon makes no
> difference at all, as it doesn't even see the virtual application.
> Any thoughts or ideas? Classic. Post, then immediately "discover" the answer.
I had the monitors configured like this:
#2 #1
Turns out, they needed to be like this:
#1 #2
Dumb! But, whatever. Can anyone fathom a reason why the brilliant
folks at MSFT apparently can't cope with negative screen coordinates?
[.NET: It's About Trust!]
