Internet connection when box uses wireless USB?
  1. #1
    csmba Guest
    My Windows 7 box uses a GW-USMicroN USB stick to connect to my router and
    give me happy internet connection.
    When I try to make a virtual PC (that runs windows XP pro) I have no idea
    how to make the VM connect to the internet.
    when I had a network cable plugged,.. it just worked automatically, but the
    VM is not seeing or being able to use the internet connection the physical
    box has.. why?
  2. #2
    Bo Berglund Guest
    Re: Internet connection when box uses wireless USB?
    On Fri, 11 Dec 2009 23:43:01 -0800, csmba
    >box has.. why?
    Probably because it is not seen by the host as a network card. Only
    network cards seem to be possible to share to the VPC guests.
    My guess is that the USB device is seen as a modem on your host and
    therefore it is not useful as a NIC to VPC.
    But you should be able to set up Shared Networking on the host and use
    this as the connection to the Internet from the guest. You won't be
    able to communicate between the host and guest that way though.
    Bo Berglund (Sweden)
Internet connection when box uses wireless USB? problems?
wireless internet connection jamesb Network & Sharing 1 11 Feb 2009
Wireless Internet Connection Gonzalo Vista General 11 30 Dec 2007
Internet wireless connection Gonzalo Vista General 2 26 Dec 2007
wireless internet connection Axel Göller Vista General 1 07 Nov 2007
Wireless Internet Connection Ashley J Vista networking & sharing 1 24 May 2007
