VPC2007 Additions causes low res display
  1. #1
    Jack B. Pollack Guest
    Installed VPC 2007 SP1 and everything went fine. Also installed the security
    fix and Virtual PC 2007 hotfix package.
    Still everything working fine. Then I installed the additions. This messed
    up my display. It is running at 640 X 480 4 bit.
    Device Manager does not red "X" flag the adapter as having a problem but I
    deleted the display adapter (VM Additions S3 Trio32/64) anyway and rebooted.
    When the Additions driver reinstalls the display goes back to low res.
    If I uninstall the additions the display is OK again.
  2. #2
    Re: VPC2007 Additions causes low res display
    Forgot to mention that the VirtualPC is XP SP3
    "Jack B. Pollack" <N@newsgroup> wrote in message
    news:%23oGuwym0KHA.3652@newsgroup
    > security fix and Virtual PC 2007 hotfix package.
    > rebooted. When the Additions driver reinstalls the display goes back to
    > low res.
  3. #3
    Steve Jain Guest
    what is the monitor set to? I've seen where it gets set to a low-res monitor
    instead of a pnp one.
    > > low res.
VPC2007 Additions causes low res display problems?
VPC2007\XPVHDBootinRestart gh Virtual PC 5 18 Sep 2009
VPC2007 and USB.... Angelo Virtual PC 1 14 Nov 2008
PDA Sync in VPC2007 Kenny Virtual PC 2 10 Oct 2008
Virtual Machine Display Resolution and VM Additions James Virtual PC 8 08 Aug 2008
VPC2007/DOS CPU hog Jack Virtual PC 10 09 Jul 2008
