| | Re: Problem with Hyper-V, NCQ SATA drives; Event ID 129 from nvstor64 saying "Reset to device, \Device\RaidPort0, was issued". GIYF. http://www.seagate.com/www/en-us/sup...nloads/cuda-fw First hit on: ST3320320AS firmware site:seagate.com In general, firmware updates are only available directly from the OEM involved. So, for the Seagate drives, you go to the Seagate site. As for actual performance of the drive with and without NCQ - most of the reviews I've seen so far haven't shown a significant benefit to NCQ enablement in benchmark tests. Real world, of course, is not a benchmark, so YMMV. -- Charlie. "Bruce Sanderson" <bsanders@xxxxxx> wrote in message news:OQ6IjCe6IHA.2336@xxxxxx Quote: > This post is related to the one on 5 Jun 2008, but I think I asked the > wrong question in that one! > > The operating system is Windows Server 2008 RTM with the RTM version of > the Hyper-V role installed (Windows6.0-KB950050-x64.msu). > > The computer is a custom built with an ASUS P5N-D motherboard, which has > the NVIDIA nForce 750i SLI chipset. > > This computer has three SATA drives - two ST3320620AS and one ST3500320AS. > The ST3500320AS has two partitions, one of which is the Windows "System" > and "Boot" partition (hosts the operating system). > > If command queuing is enabled on the ST3500320AS, I get frequent System > Event Log entries with Event ID 129 from nvstor64 saying "Reset to device, > \Device\RaidPort0, was issued". > > When these Event Log entries are recorded, the system temporarily > freezes - no response to mouse or keyboard, no video updates - everything > stops for a few seconds then carries on as if nothing happened. > > Enabling command queuing on either or both of the ST3320620AS drives does > NOT cause this problem. > > The ASUS web site says that problems with NCQ has been reported with the > NVIDIA nForce 750i SLI chipset and the solution is to update the firmware > in the drive. > > Does anyone know where can I get updated firmware for the ST3500320AS or > have any other clue to resolving this problem? > > I've disabled commmand queuing on the ST3500320AS, the system works and I > don't get the Event log entries (Event ID 129 from nvsotr64) or system > freezes, but I suspect this is resulting in degraded disk (and thus > system) performance. > > -- > Bruce Sanderson > http://members.shaw.ca/bsanders > > It is perfectly useless to know the right answer to the wrong question. > > > |
| "Disable" or "Uninstall" a device in Device Manager? | Vista General | |||
| Re: Problem with Hyper-V, NCQ SATA drives; Event ID 129 from nvstor64 saying "Reset to device, \Device\RaidPort0, was issued". | Virtual Server | |||
| Vista is not assigning driver letters to external drives, claiming "Unknown Device" | Vista General | |||
| Vista is not assigning driver letters to external drives, claiming "Unknown Device" | Vista hardware & devices | |||
