| | Re: Problem with Hyper-V, NCQ SATA drives; Event ID 129 from nvstor64 saying "Reset to device, \Device\RaidPort0, was issued". "Bruce Sanderson" <bsanders@xxxxxx> wrote in message news:OQ6IjCe6IHA.2336@xxxxxx Quote: > This post is related to the one on 5 Jun 2008, but I think I asked the Quote: > question in that one! > > The operating system is Windows Server 2008 RTM with the RTM version of Quote: > Hyper-V role installed (Windows6.0-KB950050-x64.msu). > > The computer is a custom built with an ASUS P5N-D motherboard, which has Quote: > NVIDIA nForce 750i SLI chipset. > > This computer has three SATA drives - two ST3320620AS and one ST3500320AS. > The ST3500320AS has two partitions, one of which is the Windows "System" Quote: > "Boot" partition (hosts the operating system). > > If command queuing is enabled on the ST3500320AS, I get frequent System > Event Log entries with Event ID 129 from nvstor64 saying "Reset to device, > \Device\RaidPort0, was issued". (use copy symbol, including the Hex data at the end) Thanks, Edwin |
| | Re: Problem with Hyper-V, NCQ SATA drives; Event ID 129 from nvstor64 saying "Reset to device, \Device\RaidPort0, was issued". In the "Binary" which is in really a string of hex (thanks Microsoft ! great naming !) you can see the error code # for hex 0x80040081 / decimal -2147221375 IO_WARNING_RESET # as an HRESULT: Severity: FAILURE (1), FACILITY_ITF (0x4), Code 0x81 further more the Bus Target Lun is all set to 00 00 00. So, do you have a device on bus=0 target=0 lun=0 ? If so, that is the device which had a timeout, contact your storage/HBA vendor to continue investigations an event 129 is generated by storport.sys (Microsoft driver) which has a timeout on the lower level HBA driver, but reported in event log as from the HBA driver. In this case the storport.sys had a timeout, and issues a reset. "Bruce Sanderson" <bsanders@xxxxxx> wrote in message news:uvbc7Ks6IHA.2220@xxxxxx Quote: > Event Log entry as requested > > Log Name: System > Source: nvstor64 > Date: 19-Jul-2008 10:40:35 AM > Event ID: 129 > Task Category: None > Level: Warning > Keywords: Classic > User: N/A > Computer: disc2008HV.Discovery.sanderson > Description: > Reset to device, \Device\RaidPort0, was issued. > Event Xml: > <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> > <System> > <Provider Name="nvstor64" /> > <EventID Qualifiers="32772">129</EventID> > <Level>3</Level> > <Task>0</Task> > <Keywords>0x80000000000000</Keywords> > <TimeCreated SystemTime="2008-07-19T17:40:35.935Z" /> > <EventRecordID>47825</EventRecordID> > <Channel>System</Channel> > <Computer>disc2008HV.Discovery.sanderson</Computer> > <Security /> > </System> > <EventData> > <Data>\Device\RaidPort0</Data> > 000000000000000000000000000000000000810004800000000000000000</Binary> Quote: > </EventData> > </Event> > > -- > Bruce Sanderson > http://members.shaw.ca/bsanders > > It is perfectly useless to know the right answer to the wrong question. > > > > "Edwin vMierlo [MVP]" <EdwinvMierlo@xxxxxx> wrote in > message news:uVYrnKk6IHA.3480@xxxxxx Quote: > > > > "Bruce Sanderson" <bsanders@xxxxxx> wrote in message > > news:OQ6IjCe6IHA.2336@xxxxxx Quote: > >> This post is related to the one on 5 Jun 2008, but I think I asked the Quote: > >> question in that one! > >> > >> The operating system is Windows Server 2008 RTM with the RTM version of Quote: > >> Hyper-V role installed (Windows6.0-KB950050-x64.msu). > >> > >> The computer is a custom built with an ASUS P5N-D motherboard, which Quote: Quote: > > the Quote: > >> NVIDIA nForce 750i SLI chipset. > >> > >> This computer has three SATA drives - two ST3320620AS and one > >> ST3500320AS. > >> The ST3500320AS has two partitions, one of which is the Windows Quote: Quote: > > and Quote: > >> "Boot" partition (hosts the operating system). > >> > >> If command queuing is enabled on the ST3500320AS, I get frequent System > >> Event Log entries with Event ID 129 from nvstor64 saying "Reset to > >> device, > >> \Device\RaidPort0, was issued". > > Can you post the full 129 event ? > > (use copy symbol, including the Hex data at the end) > > > > Thanks, > > Edwin > > > > |
| | Re: Problem with Hyper-V, NCQ SATA drives; Event ID 129 from nvstor64 saying "Reset to device, \Device\RaidPort0, was issued". in line "Bruce Sanderson" <bsanders@xxxxxx> wrote in message news:el7fj8G7IHA.4192@xxxxxx Quote: > Edwin - thank you for your interest and response. > > I'm aware that not every problem has a solution, problems have to be > prioritized and maybe this one is pretty low on the list, but perhaps > someone reading this newsgroup knows someone in Microsoft, NVIDIA or Quote: > that might be interested in pursuing it. > > This computer is in a very small, test/experimental environment, so there Quote: > definitly nothing "mission critical" here, but I'm always interested in > learnig about how things work; investigating problems is often quite > enlightning, particularly in these newsgroups! The computer has an Intel > Quad core Q6600 and 8 GB RAM, so it runs Windows Server 2008 with Hyper-V > quite well. > > I've reported the problem to ASUS, NVIDIA and Seagate. ASUS say the don't > support Windows Server on this motherboard (P5N-D). No response from > Seagate or NVIDIA yet. > > Here's some additional information/clarification. > > 1. there are no SCSI or Fibre Channel devices in this system. All of the > drives are directly connected to the NVIDIA SATA controller on the > motherboard. So, there are no "HBA"s as understand the term. > > 2. Here's the configuration as reported by Device Manager using the Quote: > by Connection View > a. PCI bus > i. NVIDIA nForce Serial ATA Controller: Properties, Location: PCI Quote: > 0, device 14, function 0 > a) Port 0 ST3320620AS > 1) [ST332062 0AS SCSI Disk Drive - Properties - Location: Bus > Number 1, Target Id 1, LUN 0] > b) Port 1 ST3500320AS > 1) [ST350032 0AS SCSI Disk Drive - Properties - Location: Bus > Number 0, Target Id 0, LUN 0] binary data of the event (see my previous post). Quote: > > ii. NVIDIA nForce Serial ATA Controller: Properties, Location: PCI Quote: > 0, device 15, function 0 > a) Port 0 HL-DT-ST DVDRAM GH20NS10 > 1) [HL-DT-ST DVDRAM GH20NS10 SCSI CdRom Device - Properties - > Location: Bus Number 0, Target Id 0, LUN 0] would not be my suspect Quote: > b) Port 1 ST3500320AS > 1) [ST350032 0AS SCSI Disk Drive Properties - Location: Bus > Number 1, Target Id 1, LUN 0] > > 3. I don't know why Windows Server 2008 Device Manager reports these Quote: > as "SCSI" instead of "SATA". I have exactly the same motherboard (ASUS > P5N-D) in another computer that is running Vista 64 bit SP1 and Device > Manager on that system also reports the SATA drives as "SCSI". Quote: > > 3. I've determined by experiment that the only device which causes the 129 > Event Log entries when it's "Port" (2.a.i.b) has command queueing enabled Quote: > the ST3500320AS drive (2.a.i.b)1)). Enabling command queueing on the Quote: > two disk drives DOES NOT cauase the 129 Event entries. Although on the website it details that this drive supports NCQ. Quote: > > 4. The NVIDIA site has a KB artice > (http://nvidia.custhelp.com/cgi-bin/n...er/std_alp.php > article # 768) that indicates some problems with NCQ with SATA drives with Quote: > different chipset (680i). The remedy there is to update the firmware on Quote: > drive. Charlie pointed me to page on the Seagate site about firmware > updates, but that page specifically says that the updated do not apply to > this particular drive (ST3500320AS). There are posts on the Seagate site > where some people have non-the-less attempted to "update" the firmware Quote: > SD15 to AD14) and essentially ruined the drive. So, this does not appear Quote: > be a solution to this particular problem > > 5. Charlie points out that any performance improvement from command Quote: > is likely to be marginal, so I'm willing to live with command queuing > disabled. test/experimental environment" you need to ask yourself the question if it is worthwhile pursuing |
| | Re: Problem with Hyper-V, NCQ SATA drives; Event ID 129 from nvstor64 saying "Reset to device, \Device\RaidPort0, was issued". Thanks for the info, Edwin. NVIDIA says talk to ASUS; ASUS says "2008 not supported"; no response from Seagate yet. I don't think I will do any more on this, just live with it! -- Bruce Sanderson http://members.shaw.ca/bsanders/ It's perfectly useless to know the right answer to the wrong question. "Edwin vMierlo [MVP]" <EdwinvMierlo@xxxxxx> wrote in message news:%233MvS3l7IHA.3652@xxxxxx Quote: > in line > > "Bruce Sanderson" <bsanders@xxxxxx> wrote in message > news:el7fj8G7IHA.4192@xxxxxx Quote: >> Edwin - thank you for your interest and response. >> >> I'm aware that not every problem has a solution, problems have to be >> prioritized and maybe this one is pretty low on the list, but perhaps >> someone reading this newsgroup knows someone in Microsoft, NVIDIA or Quote: >> that might be interested in pursuing it. >> >> This computer is in a very small, test/experimental environment, so there Quote: >> definitly nothing "mission critical" here, but I'm always interested in >> learnig about how things work; investigating problems is often quite >> enlightning, particularly in these newsgroups! The computer has an Intel >> Quad core Q6600 and 8 GB RAM, so it runs Windows Server 2008 with Hyper-V >> quite well. >> >> I've reported the problem to ASUS, NVIDIA and Seagate. ASUS say the don't >> support Windows Server on this motherboard (P5N-D). No response from >> Seagate or NVIDIA yet. >> >> Here's some additional information/clarification. >> >> 1. there are no SCSI or Fibre Channel devices in this system. All of the >> drives are directly connected to the NVIDIA SATA controller on the >> motherboard. So, there are no "HBA"s as understand the term. >> >> 2. Here's the configuration as reported by Device Manager using the Quote: >> by Connection View >> a. PCI bus >> i. NVIDIA nForce Serial ATA Controller: Properties, Location: PCI Quote: >> 0, device 14, function 0 >> a) Port 0 ST3320620AS >> 1) [ST332062 0AS SCSI Disk Drive - Properties - Location: Bus >> Number 1, Target Id 1, LUN 0] >> b) Port 1 ST3500320AS >> 1) [ST350032 0AS SCSI Disk Drive - Properties - Location: Bus >> Number 0, Target Id 0, LUN 0] > This is the one with B,T,L=0,0,0 -- this would be my suspect based on the > binary data of the event (see my previous post). > Quote: >> >> ii. NVIDIA nForce Serial ATA Controller: Properties, Location: PCI Quote: >> 0, device 15, function 0 >> a) Port 0 HL-DT-ST DVDRAM GH20NS10 >> 1) [HL-DT-ST DVDRAM GH20NS10 SCSI CdRom Device - Properties - >> Location: Bus Number 0, Target Id 0, LUN 0] > This one has also a B,T,L=0,0,0 -- because this is a CDrom device, this > would not be my suspect > Quote: >> b) Port 1 ST3500320AS >> 1) [ST350032 0AS SCSI Disk Drive Properties - Location: Bus >> Number 1, Target Id 1, LUN 0] >> >> 3. I don't know why Windows Server 2008 Device Manager reports these Quote: >> as "SCSI" instead of "SATA". I have exactly the same motherboard (ASUS >> P5N-D) in another computer that is running Vista 64 bit SP1 and Device >> Manager on that system also reports the SATA drives as "SCSI". > Interesting, did not notice this until now, must keep an eye out > Quote: >> >> 3. I've determined by experiment that the only device which causes the 129 >> Event Log entries when it's "Port" (2.a.i.b) has command queueing enabled Quote: >> the ST3500320AS drive (2.a.i.b)1)). Enabling command queueing on the Quote: >> two disk drives DOES NOT cauase the 129 Event entries. > ah ! good info, definitely worth while relaying to HD support (seagate) > Although on the website it details that this drive supports NCQ. > > Quote: >> >> 4. The NVIDIA site has a KB artice >> (http://nvidia.custhelp.com/cgi-bin/n...er/std_alp.php >> article # 768) that indicates some problems with NCQ with SATA drives with Quote: >> different chipset (680i). The remedy there is to update the firmware on Quote: >> drive. Charlie pointed me to page on the Seagate site about firmware >> updates, but that page specifically says that the updated do not apply to >> this particular drive (ST3500320AS). There are posts on the Seagate site >> where some people have non-the-less attempted to "update" the firmware Quote: >> SD15 to AD14) and essentially ruined the drive. So, this does not appear Quote: >> be a solution to this particular problem >> >> 5. Charlie points out that any performance improvement from command Quote: >> is likely to be marginal, so I'm willing to live with command queuing >> disabled. > Back to your original remark "This computer is in a very small, > test/experimental environment" you need to ask yourself the question if it > is worthwhile pursuing > > > > |
| "Disable" or "Uninstall" a device in Device Manager? | Vista General | |||
| Re: Problem with Hyper-V, NCQ SATA drives; Event ID 129 from nvstor64 saying "Reset to device, \Device\RaidPort0, was issued". | Virtual Server | |||
| Vista is not assigning driver letters to external drives, claiming "Unknown Device" | Vista General | |||
| Vista is not assigning driver letters to external drives, claiming "Unknown Device" | Vista hardware & devices | |||
