| | Guest Operating System will not hold onto CD ROM Drive I am running Server 2003 as a guest operating system on Virtual Server 2005. When I try to access the CD ROM on the guest os it tells me nothing is in the drive. I stop the guest os and go into server 2005, remove and add the cd rom mapping and then restart the guest os. The CD ROM is then functional until the next time I have to open the drive to insert a cd then I have to go through the entire process again. HELP |
| Virtual Guest reboots Host Operating System | Virtual PC | |||
| Unexpected shut down of the guest operating system. | Virtual Server | |||
| How to adjust screen resolution of guest operating system xp | Virtual PC | |||
| Getting Guest Operating System Name | Virtual Server | |||
| virtualization using hard drive with pre-existing operating system | Vista General | |||
