| | problems using virtual hard disks (VHD) with XP, VHDMount I installed the latest version of Virtual Server w/VHDMount, and the "take 2" registry Ben Armstrong posted on his blog for quickly mounting VHD files (see http://blogs.msdn.com/virtual_pc_guy...it-take-2.aspx or http://blogs.msdn.com/virtual_pc_guy...aspx?q=vhd&p=1 for all his VHDMount articles) and am having a lot of issues.... I am hoping someone will be able to point out something obvious I did wrong so I can get this to work... I tried created a VHD image using Microsoft Virtual PC 2007 (I have tried both dynamic and fixed-size) and partitioned/formatted them with NTFS. I right-clicked on the VHD file and selected "plug in". NOTE: what I describe happens whether I use the right-click options, or from the command prompt use VHDMount.exe /p VHDFileName and VHDMount.exe /u /c VHDFileName The first thing strange is the drive did not appear in My Computer so I opened Computer Management > Disk Management and see the drive (shows up as Disk 6, I have a media card reader that takes up 2-5) is there but offline/disabled. When I right-click it for Properties, I can enable it from the dropdown. Or I can goto Device Manager > Disk drives and it is listed with a red X, and I can right-click and enable it. At this point it gets a drive letter. I never had any issue with the driver - although just to be sure I tried following the instructions to update the driver and pointed it to the .inf files in C:\Program Files\Microsoft Virtual Server\Vhdmount\ (vhdbus.inf and vhdstor.inf) but Windows says these are not drivers for the device. It seems to already have a working driver for this. In any case, once I enable the drive, I get a drive letter and can then copy files to the partition... sometimes. I have a few large folders with many files (almost 4 GB, ~14,000 files) and when I try copying the files with Explorer, it starts to work, but then I get an error saying Windows cannot complete the task. So I have to use my file compare utility (Beyond Compare 2.x). Sometimes it works (sort of) if there aren't too many files or the file directory structure isn't too deep. But then when I am done, I don't seem to be able to unmount the drive. I right click on the VHD file and select Unplug (commit changes) and nothing happens - the drive letter still appears in My Computer and Disk Management. It is only when I disable the drive in Disk Management or Device Manager that I hear the chime (the sound you hear when you Safely Remove Hardware) and the drive letter goes away. Then if I try to re-enable, Windows asks me to reboot (really inconvenient), and usually the system gets unstable. But usually I don't get that far - usually Beyond Compare locks up 1/3 or 1/2 of the way through copying the files. At this point Windows gets very unstable, to where it is totally unresponsive except for my being able to move the mouse pointer. I am unable to kill Beyond Compare or Explorer in Task Manager, open any Windows in Explorer, or shut down the PC without killing the power, let alone Unplug the VHD to commit the changes. After much frustration I gave up and tried a 3rd party program (WinImage.com) but it doesn't seem to work with VHD files except for letting you read & copy files from NTFS-formmated volumes (no write). Supposedly it supports writing to FAT32 volumes, but I can't even get it to open a FAT32-formatted VHD file, it thinks it's unformatted. And it doesn't support mounting VHD files to a drive letter, you have to use its interface, so I can't use Beyond Compare or other utility with it. I have seen people posting how VHDMount works so great for them, I am wondering if there is anything obvious I am doing wrong, or if it has to do with my antivirus (McAfee's AOL edition), which does not seem to allow me to make VHD files "exempt" from virus scanning. Any help appreciated! ---------- Articles: Double clicking on a VHD to mount it (take 2) http://blogs.msdn.com/virtual_pc_guy...it-take-2.aspx Playing with the final version of VHDMount http://blogs.msdn.com/virtual_pc_guy...-vhdmount.aspx Using VHDMount under Windows XP http://blogs.msdn.com/virtual_pc_guy...05/740763.aspx Downloads: Download Microsoft Virtual Server 2005 R2 SP1 today http://technet.microsoft.com/en-us/e.../bb738033.aspx Download or Order Virtual Server 2005 R2 SP1 Enterprise Edition for Free http://www.microsoft.com/technet/vir...e/default.mspx WinImage utility http://winimage.com/winimage.htm |
| Can I combine two hard disks together? | Vista hardware & devices | |||
| Performance penalty between dynamic- and fixed-size virtual hard disks? | Virtual PC | |||
| External hard disks | Vista hardware & devices | |||
| problems using virtual hard disks (VHD) with XP, VHDMount | Virtual PC | |||
| USB hard disks | Vista General | |||
