| | RE: Shutdown Guest OS Script Problem Quote: > I am using the following code to shutdown a virtual machine... > > Set objVS = CreateObject("VirtualServer.Application") > Set objVM = objVS.FindVirtualMachine("Virtual Machine Name") > > Set objGuestOS = objVM.GuestOS > objGuestOS.Shutdown() > > .... this works most of the time, however on some occasions I get the error > "The guest operating system could not be shutdown", error number 2147024809. > > The machine is still in a useable state (i.e. not crashed or frozen). The > only thing I can think of is that the machine may still have applications > running. Would this cause this error, and if so is there anything I can do to > force the machine to close the applications and shutdown. The virtual > machines may not always have a network connection, so I cannot call > shutdown.exe remotely. > > Any help is greatly appreciated. Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com |
| Shutdown and startup Hyper-V Virtual Machine via script | Virtual Server | |||
| Script to delete files on shutdown | VB Script | |||
| Shutdown guest OS problem | Virtual Server | |||
| Guest OS in VS2005 cannot be shutdown normally | Virtual Server | |||
| Group Policy - I need to write a script to run on shutdown | Vista security | |||
