| | RE: Virtual Machines - COM Port Validation Problems Quote: > I have a COM port issue with configuring a virtual machine. > > My host hardware has 1 COM port (COM1), and I have installed a RapidPort/4 > USB 4-port modem bank which register as COM3, COM4, COM5, and COM6. All have > been setup as modems under Phone and Modems. > > RRAS is using COM3 and COM4 for dial-up. > > I can use Hyper-terminal to talk to COM5 and COM6, executing simple AT > commands like ATI1 to verify that I am actually communicating with an open > port. > > When I try to configure my virtual machine to consume COM5 and COM6 (they > appear in the drop down menu) as guest ports COM1 and COM2, I get the > following error message. > > ---------- > The COM port settings could not be saved. The configuration value could not > be set. The value is out of range. > ---------- > > However, if I edit the .vmc file to use COM5 and COM6 and boot the virtual > machine, I can talk to these ports from the guest machine. It appears to > simply be an issue with the configuration editor. > > Anyone else experience something like this? Host Server has 2 FAX MODEMS, one in COM4 the other one in COM5, Virtual Server only recognizes COM4 , but this is been used by FAX services at the HOST, Tried to select COM5 to be attached to COM2 on the virtual machine, got the same "OUT OF RANGE alert Manually edit .vmc file with no result PLEASE HELP!!!!!! Posted via http://www.VirtualServerFaq.com - Brought to you by Business Information Technology Shop - http://www.bitshop.com |
| Missing Virtual Machines | Virtual Server | |||
| virtual machines on C drive........ | Virtual Server | |||
| How To: Windows Performance Monitor Virtual Switch Port instance IDto Virtual NIC or VM | Virtual Server | |||
| XP SP3 updated 3 virtual machines | Virtual PC | |||
| a tip for virtual machines | Vista General | |||
