Go Back   Vista Forums > Misc Newsgroups > Virtual Server
Vista - Virtual Networking Problems
Old 08-21-2009   #1 (permalink)
Simon Gronow
Hi
I'm trying to setup a Virtual Network with it's own subnet to free up some
of our main subnet's ip's from Virtual Machines.
I have created a Microsoft Local Loopback (without a default g/w) which I
can ping from a workstations, but I can't ping the VM guest machines.
I have changed the network setup of the guest VM's to Virtual Network.
I don't want to use Nat just want the two subnet's to talk.
The Setup
Main Subnet
192.168.1.x
192.168.1.44 Virtual Server (Host)
192.168.1.100 - 200 workstations
192.168.1.254 - adsl router (Default Gateway for all Pc's on this subnet)
Virtual Subnet
192.168.100.x
192.168.100.1 Loopback Nic on the Virtual Server (aka 192.168.1.44)
192.168.100.10 First Virtual PC with a Gateway of 192.168.100.1
From 192.168.1.100 I can ping 192.168.1.44 & 192.168.100.1 no problems
From 192.168.1.44 I can ping 192.168.1.100 & 192.168.100.10 no problems
From 192.168.1.100 I can NOT ping 192.168.100.10
Form 192.168.100.10 I can NOT ping 192.168.1.100
Tried some routing tables from the router for 192.168.100.x to 192.168.1.44
and on the vm's back the other way - no go.
What I have missed to make this work?
One thought I had was do you need to setup Routing and Remote Access Service
on the VM Host?
Thanks
Rgds
Simon.
Old 08-21-2009   #2 (permalink)
Bill Grant
Re: Virtual Networking Problems
"Simon Gronow" <srg@newsgroup> wrote in message
news:#o1aYLlIKHA.1340@newsgroup
Quote:
> Hi
> The Setup
> Main Subnet
> 192.168.1.x
> Virtual Subnet
> 192.168.100.x
> 192.168.1.44 and on the vm's back the other way - no go.
> Service on the VM Host?
> Thanks
> Rgds
> Simon.
The problem has nothing to do with virtual machines or virtual networks.
You cannot get from one IP subnet to another without an IP router.
If your vms are in the virtual network linked to the loopback adapter,
you would need to enable IP routing or the host to route between the
physical network and the virtual network. The vms would need to use the
loopback adapter as their default gateway and the physical machines would
need to use the host's physical NIC as their dg.
If the LAN machines use some other router as their dg, you will need some
static routing to make it work. Here is an example of each case.
If both networks can use the router as a default gateway, everything works
without static routes. All you need to do is enable IP routing.
eg 192.168.1 x dg 192.168.1.1
192.168.1.1 dg blank
router
192.168.100.1 dg blank
192.168.100.x dg 192.168.100.1
If the 192.168.1 subnet uses some other gateway, you need extra
routing to get the traffic to the new router. This route needs to be on your
Internet router, not the new one.
Internet
ADSL
192.168.1.254
192.168.1.x dg 192.168.1.254
192.168.1.n dg 192.168.1.254 host
host router
192.168.100.1 dg blank (loopback adapter)
If you configure it as a NAT router, it will work without static
routes. If you configure it as a LAN router, you need the extra routing on
the adsl router to get the traffic to the second router. eg 192.168.100.0
255.255.255.0 192.168.1.n
Personally I would not do it that way. I like to keep the host out of the
routing setup. I would put the vms in a private network and use a vm as the
router. The routing is essentially the same but you install RRAS in a vm,
not on the host.
Old 08-24-2009   #3 (permalink)
Simon Gronow
Hi Bill,
All sorted thanks for your help.
"Bill Grant" <not.available@newsgroup> wrote in message
news:%23EetnNtIKHA.1488@newsgroup
Quote:
>> Hi
>> some of our main subnet's ip's from Virtual Machines.
>> The Setup
>> Main Subnet
>> 192.168.1.x
>> Virtual Subnet
>> 192.168.100.x
>> Thanks
>> Rgds
>> Simon.
> some static routing to make it work. Here is an example of each case.
> works without static routes. All you need to do is enable IP routing.
> router
> your Internet router, not the new one.
> Internet
> ADSL
> 192.168.1.254
> host router
> 192.168.100.0 255.255.255.0 192.168.1.n
> the router. The routing is essentially the same but you install RRAS in a
> vm, not on the host.
Old 08-24-2009   #4 (permalink)
Bill Grant
Fine. Didn't realise that you were another Aussie!
news:uNwZ3KJJKHA.3928@newsgroup
Quote:
> Hi Bill,
Quote:
>>> Hi
>>> I can ping from a workstations, but I can't ping the VM guest machines.
>>> The Setup
>>> Main Subnet
>>> 192.168.1.x
>>> subnet)
>>> Virtual Subnet
>>> 192.168.100.x
>>> Thanks
>>> Rgds
>>> Simon.
>> networks. You cannot get from one IP subnet to another without an IP
>> router.
>> router
>> Internet
>> ADSL
>> 192.168.1.254
>> host router
>> on the adsl router to get the traffic to the second router. eg
>> the routing setup. I would put the vms in a private network and use a vm
>> as the router. The routing is essentially the same but you install RRAS
>> in a vm, not on the host.
Perplexed about networking 2 Virtual Machines in VPC2007 Virtual PC
Virtual Server Networking Virtual PC
Virtual PC networking questions Virtual Server
Networking in Virtual PC Virtual PC
Vista Ultimate and Virtual PC 2007 networking Vista General
