| | How to know virtual machine base machine ip Hi, After login to the virtual pc using RDP how to know the base machine ip using command or script or any other ways. |
| | Re: How to know virtual machine base machine ip On Sat, 12 Sep 2009 21:51:01 -0700, Gopal <Gopal@newsgroup> wrote: Quote: >Hi, >After login to the virtual pc using RDP how to know the base machine ip >using command or script or any other ways. ipconfig /all ???? -- Bo Berglund (Sweden) |
| How to know vPC 2007 base machine ip | Virtual PC | |||
| error: Virtual PC could not open the Virtual Machine Network Servicesdriver | Virtual PC | |||
| Virtual PC 2004 upgrade to 2007 Add an existing virtual machine | Virtual PC | |||
| Re: WSUS 3.0 SP1 Running as a Virtual Machine in Virtual Server 2005 | Virtual Server | |||
| Unable to install Virtual Guest Services on virtual machine | Virtual Server | |||
