Go Back   Vista Forums > Misc Newsgroups > Virtual Server
Vista - Strange Hyper-V VM network problem
Old 09-21-2009   #1 (permalink)
Miha
Hi
Running Windows Server 2008 ENT SP2 with Hyper-V enabled with 4 NICs. 3 of
them are used for virtual machines.
We're facing with a strange problem. When we shut-down virtual machine and
start it up again the NIC inside VM don't get IP addres. So I need to remove
and reinstall NIC on VM properties, then restart VM a few times and it
suddenly starts working.
But when we restart (not shut-down) VM, all IP addresses are set without any
problems. All VM are Windows XP/2003/2008.
I'm running crazy, don't know what to check next. Any ideas?
Regards,
Miha
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4442 (20090921) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
iSCSI and Public/Private network problem when clustering with Hyper-V Virtual Server
RE: Strange XP-Vista network problem Vista networking & sharing
Re: Strange XP-Vista network problem Vista networking & sharing
Strange Network Problem Vista networking & sharing
Strange network problem - Can't save in Office2007 on network driv Vista networking & sharing
