Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Newsgroups > Vista file management
VSS idle timeout. shadow copy does not work.
Closed Thread
Thread Tools Display Modes
Old 11-01-2007   #1 (permalink)
pj
Guest
i am running vista ultimate...
and my shadow copy is no longer working.. it hasn't for months!
it did when i first got my system (dell inspiron 9400)!.. i think i disabled
it... but have
re-enabled it... but to no avail.. i have system backup set to auto...
windows shadow copy set back to auto (was disabled) (under services)
and when i right click a folder, and goto previous versions.. it is empty...
i have checked my even log viewer.. and it i get the following:
-The Windows Modules Installer service entered the running state.
-DCOM started the service VSS with arguments "" in order to run the server:
{E579AB5F-1CC4-44B4-BED9-DE0991FF0623}
-The VSS service is shutting down due to idle timeout.
any idea as to what could be causing this? i tried figuring this one out
months ago.. but gave up...
im now determined to figure it out!
any help would be much appreciated!
thanks
pj
Old 11-02-2007   #2 (permalink)
pj
Guest
RE: VSS idle timeout. shadow copy does not work.
if i cant get help here, where, oh where can i?
come on! anyone?
p
Old 11-02-2007   #3 (permalink)
Ronnie Vernon MVP
Guest
Re: VSS idle timeout. shadow copy does not work.
PJ
Do you have System Restore enabled on the system drive (C? The system
restore files is where all of the previous version shadow copies are saved.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
"pj" <pj@xxxxxx> wrote in message
news:1535922C-FE57-43B1-948F-DA55D026F18B@xxxxxx
> disabled
> it... but have
> empty...
> server:
> thanks
> pj
Old 11-03-2007   #4 (permalink)
pj
Guest
yes, i have it checked to monitor drive C, the drive i want shadow copies to
work on...
i have checked, and rechecked..
p
Old 11-04-2007   #5 (permalink)
Bert Kinney
Guest
Each time System Restore is disabled, all shadow copies, including Restore
Points and Previous Versions are deleted.
Now that System Restore is enabled on C:, right click on the Command Prompt
and select Run as administrator. Then paste the following command and press
enter. This will displays all shadow copy storage associations on the system.
vssadmin list shadowstorage
In the command prompt right click on the upper left conner of the title bar
and select Edit - Select All then press enter. This will place the contents
of the command prompt into the clip board. Now paste the results here.
Regards,
Bert Kinney MS-MVP Shell/User
http://bertk.mvps.org
Member: http://dts-l.org
pj wrote:
> work on...
> p
Old 11-05-2007   #6 (permalink)
pj
Guest
im on the road right now.... be back after thanksgiving... thanks for posting.
pj
"Bert Kinney" wrote:
Quote:
> Hi,
> Regards,
> pj wrote:
> > work on...
> > p
Old 11-25-2007   #7 (permalink)
pj
Guest
ok, im back, and did like you said BERT...
here are the results:
pj
C:\Users\ME>vssadmin list shadowstorage
vssadmin 1.1 - Volume Shadow Copy Service administrative command-line tool
(C) Copyright 2001-2005 Microsoft Corp.
Shadow Copy Storage association
For volume: (C\\?\Volume{155e5023-0a83-11dc-94e1-806e6f6e6963}\
Shadow Copy Storage volume:
63}\
Used Shadow Copy Storage space: 678.664 MB
Allocated Shadow Copy Storage space: 970.223 MB
Maximum Shadow Copy Storage space: 2 GB
Old 12-02-2007   #8 (permalink)
pj
Guest
Bert ya there!? anybody.... would really like to figure this one out!!!
thanks
pj
Old 01-09-2008   #9 (permalink)
pj
Guest
grrr.. disspointing, no one helped me out...
i just wanted to post back on here, for anyone else who seems to be having
this problem.....
turns out TUNEBIT (which i dont use,) causes problems with VSS...
my problem was, i disabled admin shares... check the following yourself
goto RUN, type regedit and:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanserver\parameters,
and create two new DWORD values, AutoShareServer and AutoShareWks, both set
to 1
pj
Old 01-09-2008   #10 (permalink)
pj
Guest
grrr.. disappointing, no one helped me out...
this problem.....
to 1
pj
Closed Thread
Display Modes
Shadow Copy.... Lance11 General Discussion 13 2 Weeks Ago 09:56 AM
about shadow copy best friend Vista General 0 05-03-2008 06:41 PM
How do I get dialup idle timeout to work with incoming network pro yyj Vista networking & sharing 0 10-04-2007 10:49 AM
dialup modem idle timeout does not work yyj Vista General 0 10-03-2007 11:06 AM
Shadow Copy: Force Copy Creation? Jack Vista General 0 05-06-2007 01:12 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
