Go Back   Vista Forums > Vista Newsgroups > Vista file management
Vista - Search index problem
Old 12-28-2007   #1 (permalink)
davereyn83
Dear Folks,
I've got three Windows Vista Extended Home Edition issues--they appear
to be related but may not be--that are baffling me. The first problem
involves the Search Indexer, which has stopped working, and despite my
best efforts, cannot be turned back on.
The second problem is that I can't seem to complete a Restore session,
yet I can create Restore points without any problem. I've tried it
several times using different dates, including before a new video card
was installed (see background below), with no success. Problem #3 is
that when I go into Sleep mode, I can't come out of it. I'm forced to
turn the computer completely off.
The background:
These problems did not exist until I augmented my computer with a PNY
PCI Extended 8500 graphics card with 512MB of RAM on Dec. 24.
Before I installed the new video card (and several Windows updates
related to the upgrade), I did not get this message: "Microsoft Search
Indexer has stopped working and was closed. A problem caused the
application to stop working correctly. Windows will notify you if a
solution is available."
Doing a Find (Windows key plus F) allows me to turn indexing on, yet
it fails to do so.
Regarding the sleep mode issue, it's been suggested that I remove both
video drivers then only reinstall the one that came with my new card.
I'm reluctant to do so since I intend to use both card simultaneously
with a 22-inch monitor connected to it and a 17-inch monitor connected
to the original card.
Hardware configuration
The computer has an on-board graphics card with a shared 64MB of video
RAM. I have 1.5GB of RAM, two internal hard drives of about 200GB each
and a pair external 512GB drives configured in a RAID system.
Software:
Windows Vista Extended Home Edition upgrade from Windows XP
Microsoft Office 2003 plus Vision 2007
Adobe Creative Suite 3
Symantec Internet Security 2007 with the Norton firewall turned off
Windows Defender is on
Any comments or suggestions would be extremely helpful.
Sincerely,
David B. Reynolds
Windows Vista ultimate x64 Search engine issues - Search fails to index Vista General
Problem Disabling Vista Search Index Vista General
Search Index General Discussion
Search Index Vista performance & maintenance
opening a file within Windows Search Index problem Vista file management
