Go Back   Vista Forums > Vista Newsgroups > Vista file management
Vista - vista ultimate build in partition utility problem
Old 01-05-2008   #1 (permalink)
Vista Ultimate 32bit
hi, i have a 320GB HD, using the built in disk managment partition utility, i was only able to partition my C drive down to 200GB. dose anyone know of a solution for this other than a 3rd party program??
I cant activate Vista ultimate 6.6000 build General Discussion
I'm having latency problems w/Vista Ultimate on my new build. Vista networking & sharing
Vista Ultimate RC2 Build 5744 Vista General
Can't update vista 64 Ultimate RTM build 6000 Vista General
System configuration utility in Vista Ultimate 32 Vista performance & maintenance
