Go Back   Vista Forums > Vista Newsgroups > Vista file management
Vista - Display Problem
Old 01-23-2008   #1 (permalink)
Martin Racette
Display Problem
When I open the Documents folder(or any other folder), I have on the left
hand side some folder that I can access, and at the bottom there an arrow
where you can make the folder tree appear. Up to there no problem, but when
I'm trying to scroll through the tree the whole thinmg keeps moving left and
right on it own
How can I make it stop moving and remain to the left
Thank You in Advance
Merci a l'avance
Martin
Old 01-24-2008   #2 (permalink)
Dwarf
RE: Display Problem
Hi Martin,
This is not actually a problem, rather it is a 'feature' that is built-in to
Vista. The purpose of this is when you click on a folder it shows the full
name of the folder in the left hand pane (or as much of it as can be
physically displayed). To reduce the number of times this feature kicks in
you will need to alter the width of this column. If you hover over the
vertical dividing line between the left hand folder pane and the right hand
contents pane you will see that the cursor changes to a horizontal 2-way
pointing arrow. If you left click and drag, the line will move in the
direction you drag it and you can make the folder pane wider or narrower (the
contents pane will, obviously, do the reverse).
Dwarf
"Martin Racette" wrote:
Quote:
> Hi,
> right on it own
> Merci a l'avance
> Martin
Display Problem / Graphics Problem Drivers
problem with the display Graphic cards
jpg display problem Vista music pictures video
Problem with display Vista General
display problem Vista hardware & devices
