| | Recycle Bin Help Somehow when I was wiping off my keyboard I must have renamed my recycle bin (you know how that stuff happens) ... so I saw that it was numbered. I renamed it Recycle Bin like it should be. Well when I go into Personalization Quote: > Change Desktop Icons on the top left it shows 2 recycle bins ~ 1 empty and underneath the correct ones. The problem is that when I empty the recycle bin depending on which one is on my desktop, it doesn't change ... in other words .... it doesn't matter if I have the empty or full one on my desktop ... if I put something in it and *empty recycle* bin, it doesn't change to empty or vice versa. In short lol ... what did I do and how do I restore them? I tried to hit *restore icon* and that didn't work. This is making me nuts ... any help is appreciated. Thanks! |
| | Re: Recycle Bin Help Hi harleynan13, This is a common problem occurs when you use the "Restore Default" button. Here is an easy fix. See: Recycle Bin icon does not refresh automatically: http://www.winhelponline.com/article...matically.html -- Regards, Ramesh Srinivasan, Microsoft MVP [Windows Shell/User] Windows® Troubleshooting http://www.winhelponline.com "harleynan13" <harleynan13@xxxxxx> wrote in message news:0B3738AD-B456-470E-B9B2-4FBF11A70AD0@xxxxxx Somehow when I was wiping off my keyboard I must have renamed my recycle bin (you know how that stuff happens) ... so I saw that it was numbered. I renamed it Recycle Bin like it should be. Well when I go into Personalization Quote: > Change Desktop Icons on the top left it shows 2 recycle bins ~ 1 empty and underneath the correct ones. The problem is that when I empty the recycle bin depending on which one is on my desktop, it doesn't change ... in other words .... it doesn't matter if I have the empty or full one on my desktop ... if I put something in it and *empty recycle* bin, it doesn't change to empty or vice versa. In short lol ... what did I do and how do I restore them? I tried to hit *restore icon* and that didn't work. This is making me nuts ... any help is appreciated. Thanks! |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Recycle Bin Help Somehow when I was wiping off my keyboard I must have renamed my recycle bin (you know how that stuff happens) ... so I saw that it was numbered. I renamed it Recycle Bin like it should be. Well when I go into Personalization Quote: > Change Desktop Icons on the top left it shows 2 recycle bins ~ 1 empty and underneath the correct ones. The problem is that when I empty the recycle bin depending on which one is on my desktop, it doesn't change ... in other words .... it doesn't matter if I have the empty or full one on my desktop ... if I put something in it and *empty recycle* bin, it doesn't change to empty or vice versa. In short lol ... what did I do and how do I restore them? I tried to hit *restore icon* and that didn't work. This is making me nuts ... any help is appreciated. Thanks! This will show you how to fix your Recycle Bin so it will refresh again with the correct icon. Recycle Bin Shawn |
| | Re: Recycle Bin Help Oh wow, thank you so much! It's fixed! YAY! ![]() I need to wipe off my keyboard when the computer is off from now on; strange things happen when I don't LOL. Thanks again! "Ramesh, MS-MVP" wrote: Quote: > Hi harleynan13, > > This is a common problem occurs when you use the "Restore Default" button. Here is an easy fix. See: > > Recycle Bin icon does not refresh automatically: > http://www.winhelponline.com/article...matically.html > > -- > Regards, > > Ramesh Srinivasan, Microsoft MVP [Windows Shell/User] > Windows® Troubleshooting http://www.winhelponline.com |
| | Re: Recycle Bin Help You're welcome! -- Regards, Ramesh Srinivasan, Microsoft MVP [Windows Shell/User] Windows® Troubleshooting http://www.winhelponline.com "harleynan13" <harleynan13@xxxxxx> wrote in message news:ACC651FE-6134-41AC-9E97-996503DE06BE@xxxxxx Oh wow, thank you so much! It's fixed! YAY! ![]() I need to wipe off my keyboard when the computer is off from now on; strange things happen when I don't LOL. Thanks again! "Ramesh, MS-MVP" wrote: Quote: > Hi harleynan13, > > This is a common problem occurs when you use the "Restore Default" button. Here is an easy fix. See: > > Recycle Bin icon does not refresh automatically: > http://www.winhelponline.com/article...matically.html > > -- > Regards, > > Ramesh Srinivasan, Microsoft MVP [Windows Shell/User] > Windows® Troubleshooting http://www.winhelponline.com |
| Recycle Bin | Vista General | |||
| Recycle bin icon not filling/emptying when recycle bin is full/emp | Vista General | |||
| recycle bin | Vista General | |||
| RE: Recycle Bin | Vista General | |||
