Go Back   Vista Forums > Vista Newsgroups > Vista file management
Vista - My documents messed up, need help finding registry values!!
Old 05-14-2008   #1 (permalink)
Vista Ultimate x64 SP1
Okay, this is the situation, il keep it short.
I changed the target path for my documents on the start menu ( location tab )
Tried doing it again..and the location tab is gone.
Not only that but when navigating through the hard drive..
C:\Users\Respawns\Desktop
It now says..
C:\Users\Documents\Desktop
Now i cant install programs because the Application data tmp folder isnt where the programs think it is..its called Documents now instead of Respawns..
But i still login as Respawns!
I've taken ownership of everything btw.
I AM THE ADMIN.
Just need to find the registry path for the start menu and change it through there.
Thanks in advance guys i cant do anything ive just done a clean install and cant use any programs so please help!
Old 05-14-2008   #2 (permalink)
Ramesh, MS-MVP
Re: My documents messed up, need help finding registry values!!
Hi Respawns,
Option 1: Use the REG file here to reset the path for Documents/Picture/Music folders:
http://www.winhelponline.com/article...tart-menu.html
-or-
Option 2:
You can change the Documents path in the registry. See Method 2 here:
http://www.winhelponline.com/article...ows-Vista.html
(Fix the value data for "Personal".)
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
The Winhelponline Blog: http://www.winhelponline.com/blog
Windows® Troubleshooting: http://www.winhelponline.com
"Respawns" <guest@xxxxxx-email.com> wrote in message news:64be7b81e8fea897635d1f7b4de8a25d@xxxxxx-gateway.com...
tab )
It now says..
Respawns..
I AM THE ADMIN.
through there.
Respawns
Old 05-14-2008   #3 (permalink)
Omfg thanks so much you've really helped me out man ive searched everywhere for about 3 hours and didnt find a thing, and i usually find what im looking for but in this caas i didnt get anything thanks alot what can i do to pay you back lol?
Need a film, app, serial, game, patch, OS or WGA software let me know !
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Explorer \ User Shell Folders
That was all i needed to know i just wanted to make sure i was making the key in the correct place.
People like you should be paid lol
Old 05-15-2008   #4 (permalink)
Ramesh, MS-MVP
You're welcome Respawns.
Regards,
"Respawns" <guest@xxxxxx-email.com> wrote in message news:dd35c492b3d31feec91ad0596a61dc13@xxxxxx-gateway.com...
Respawns
Writing values to Registry General Discussion
Remote HKU registry values PowerShell
Reporting on registry values PowerShell
Finding and removing values in registry subkeys PowerShell
need some registry values Vista General
