| Guest | Is it possible in "computer" to view files from top to bottom in 1st column then same again in next column to the right etc? Hi, I cant seem to change the list of files from left to right,and then onto the next line down,then left to right again. THANKS |
| Wrong Addresses in "To" Column of List Pane | Live Mail | |||
| "Local Folders" Column Doesn't Open | Vista mail | |||
| can I create a new "kind" of folder with customized column heading | Vista file management | |||
| Need to Display the "Computer Description" column (like I could in XP) | Vista General | |||
| "Date Modified" Column Header Disappears | Vista General | |||
