| Vista Ultimate x64 SP2 Beta | Pls answer huge problem I use wopti ultilities. It's a great program and i got a better performance of my computer but...i used the built in defrag utility and this is what happend: On my C: partition that is about 54 GB i had 24 GB free. When i used defrag, suddenly have 300MB free and when i analized it was hugely fragmented, and i get the messege of low disk space. I used windows defrag and some other third party defrag but non help. Pls i need help how to fix the problem. Restore donn't work because it says i have low disk space!! So to sumraize... i had 24 gb free, now i have 300mb free and a badly fragmented disk after using wopti build in defrag...non other defrag help. HOW DO I FIX THIS?!?!?! |
| Ultimate x86 | Re: Pls answer huge problem Because wopi build in defrag has difficulty processing Vista's system shadow storage this happens do this: you can lower unnecessary large system shadow storage by: Clicking start >> Accessories >>right click on command >>select run as administrator >> copy and paste this syntax: C:\Windows\system32\vssadmin resize shadowstorage /On=C: /For=C: /Maxsize=2GB your System Restore shadow storage will now be resized to a maximum of 2GB you should see an immediate influx of available space Check if when Vista resizes the restore size it refragments your drive |
| Vista Ultimate x64 SP2 Beta | Re: Pls answer huge problem Because wopi build in defrag has difficulty processing Vista's system shadow storage this happens do this: you can lower unnecessary large system shadow storage by: Clicking start >> Accessories >>right click on command >>select run as administrator >> copy and paste this syntax: C:\Windows\system32\vssadmin resize shadowstorage /On=C: /For=C: /Maxsize=2GB your System Restore shadow storage will now be resized to a maximum of 2GB you should see an immediate influx of available space Check if when Vista resizes the restore size it refragments your drive |
| | Re: Pls answer huge problem Since apparently wopti utilities has only a single version, which according to their blurb requires only win98 or any other version of win. Then IMO its not worth installing on either a winnt based system or a Vista system since both are completely different to win9*, not only in the GUI but how win was actually coded. How can anyone expect a utility that runs in win9* to run correctly on a completely different version of win? If they produce a version the runs only on Vista then by all means try it, untill then steer clear. "Iceman_377" <guest@xxxxxx-email.com> wrote in message news:3c0f64e52e16b6b15bc3648de4e95c92@xxxxxx-gateway.com... Quote: > > Ultimate User;801472 Wrote: Quote: >> Because wopi build in defrag has difficulty processing Vista's system >> shadow storage this happens do this: >> >> you can lower unnecessary large system shadow storage by: >> >> Clicking start >> Accessories >>right click on command >>select run as >> administrator >> copy and paste this syntax: >> >> C:\Windows\system32\vssadmin resize shadowstorage /On=C: /For=C: >> /Maxsize=2GB >> >> your System Restore shadow storage will now be resized to a maximum of >> 2GB you should see an immediate influx of available space >> >> >> Check if when Vista resizes the restore size it refragments your drive > I had 300mb free now i have 6,79GB but that is still far away from 24GB > i had...and the disk is still VERY HIGH fragmented, and still defrag > program cant defrag. My disk wasn't so fragmented at all, i always use > regulary tuneup defrag 2008 but now it cant finish the job, something is > still a problem. HELP! > > > -- > Iceman_377 |
| Vista Ultimate x64 SP2 Beta | Re: Pls answer huge problem I solved the problem |
| | #6 (permalink) |
| | Re: Pls answer huge problem Iceman_377 wrote: Quote: > I solved the problem ![]() > > -- Dave T. I've learned that whatever hits the fan will not be evenly distributed. |
| | #7 (permalink) |
| Vista Ultimate x64 SP2 Beta | Re: Pls answer huge problem Well my hard disk wasn't at all fagmented, the reson why it showed so many fragments was because of a file that wopti maked. Wopti when run by an administrator still can't make a backup of the registry. When i tryed to do that it lasted so long i ended it in task manger. But by doing that wopti made a file that was 19,8GB BIG. When i deleted it my hard disk wasnt fragmented and now i have my 24GB back. So don't use backup regestry of wopti use manual, and don't use wopti defrag it messes up the shadow storage. But still i have to repeat. Wopti is the only utility that made my computer run faster. It has great cleaners (better than any i tryed), optimizers (realy speed up) but it has these 2 problems so don't mess with that. |
| | #8 (permalink) |
| Ultimate x86 | Re: Pls answer huge problem Wopti.....don't use it |
| | #9 (permalink) |
| Vista Ultimate x64 SP2 Beta | Re: Pls answer huge problem I think people should use wopti, it full of information and harmless cleaners. U can opitmize everything with ease, and it has that logo (cerified for Windows VIsta) Maybe the defrag wasn't the problem, it was me actualy that ended the wopti and task manager in the middle of work witch led to huge 19GB file. And last but not least, Wopti is Microsoft Partner. Use it... |
| | #10 (permalink) |
| | Re: Pls answer huge problem On checking the appropriate MS 'certified for Vista site' wopti is not listed Niether are they listed, in the US, as a Microsoft Certified Partner If you click on 'certified for vista' logo on the wopti site it simply links to a list of shareware awards, as does the Certified Partner Since some of the wopti utilities, do not work, by your own admission in Vista, the obvious conclusion is that is not Vista compatible & the 'certified logo' would thus appear to be a scam on behalf of wopti. Like most of these utilities they are 'snake oil' and should'nt be unleashed on any nt based o/s or Vista "Iceman_377" <guest@xxxxxx-email.com> wrote in message news:f0f7d34869523bdc888a4684b1bef819@xxxxxx-gateway.com... Quote: > > I think people should use wopti, it full of information and harmless > cleaners. U can opitmize everything with ease, and it has that logo > (cerified for Windows VIsta) > Maybe the defrag wasn't the problem, it was me actualy that ended the > wopti and task manager in the middle of work witch led to huge 19GB > file. And last but not least, Wopti is Microsoft Partner. Use it... > > > -- > Iceman_377 |
| Huge CPU problem | General Discussion | |||
| HUGE Vista problem... HELP! | General Discussion | |||
| huge sp 1 problem! help! | Windows Updates | |||
| Huge problem! | General Discussion | |||
| huge problem - need help | General Discussion | |||
