| | Problems starting programs using Start/Search Field/Program Name there is this small frustration i'm having with Vista's Search option. I am using Vista Home Premium [32b] [NO Service Pack installed], and there is some time now since some of my programs wouldn't open using this neat method Vista implemented introducing the "Search" field in the Start Menu. This does not happen to all the programs i have installed. It only happens with Microsoft Office and iTunes [sadly, i use these two quite a lot]. In the past, i have tried reinstalling the applications, working on the Search Index... everything seems to be alright, but, somehow there are some broken links that i can't figure. The search is successful, the program name is being offered as a result, but the program won't start when i hit "enter". nor when i right click on it and select "Open". I would really appreciate some help on the matter. Yours, Sebastian. |
| | Re: Problems starting programs using Start/Search Field/Program Name "Sebastian Trandafir" <SebastianTrandafir@xxxxxx> wrote in message news:1F54612C-24FC-4B30-92CE-9BA972613D91@xxxxxx Quote: > there is this small frustration i'm having with Vista's Search option. > > I am using Vista Home Premium [32b] [NO Service Pack installed], and there > is some time now since some of my programs wouldn't open using this neat > method Vista implemented introducing the "Search" field in the Start Menu. > > This does not happen to all the programs i have installed. It only happens > with Microsoft Office and iTunes [sadly, i use these two quite a lot]. In > the > past, i have tried reinstalling the applications, working on the Search > Index... everything seems to be alright, but, somehow there are some > broken > links that i can't figure. The search is successful, the program name is > being offered as a result, but the program won't start when i hit "enter". > nor when i right click on it and select "Open". > > I would really appreciate some help on the matter. > Yours, Sebastian. May I ask why you are using the Search function to find programs in the first place? If you have the Start menu open, why not use the menu item for either Office or ITunes and "pin" them to the Start menu? |
| | Re: Problems starting programs using Start/Search Field/Program Name "Gordon" <gordonbparker@xxxxxx> wrote in message news:eFXBTvCEJHA.2072@xxxxxx Quote: > "Sebastian Trandafir" <SebastianTrandafir@xxxxxx> wrote > in message news:1F54612C-24FC-4B30-92CE-9BA972613D91@xxxxxx Quote: >> there is this small frustration i'm having with Vista's Search option. >> >> I am using Vista Home Premium [32b] [NO Service Pack installed], and >> there >> is some time now since some of my programs wouldn't open using this neat >> method Vista implemented introducing the "Search" field in the Start >> Menu. >> >> This does not happen to all the programs i have installed. It only >> happens >> with Microsoft Office and iTunes [sadly, i use these two quite a lot]. In >> the >> past, i have tried reinstalling the applications, working on the Search >> Index... everything seems to be alright, but, somehow there are some >> broken >> links that i can't figure. The search is successful, the program name is >> being offered as a result, but the program won't start when i hit >> "enter". >> nor when i right click on it and select "Open". >> >> I would really appreciate some help on the matter. >> Yours, Sebastian. > > May I ask why you are using the Search function to find programs in the > first place? If you have the Start menu open, why not use the menu item > for either Office or ITunes and "pin" them to the Start menu? Plus the fact that you REALLY REALLY ought to install SP1 (unless you have mission -critical software that won't run with it installed, or you have drivers that are not compatible...) |
| | Re: Problems starting programs using Start/Search Field/Program Name You dont mention version of Office; Do you not have the 'New office doc' and 'Open Office doc' in your start menu. Depending on version of Office you may have to add this - see office help. And if you type Word in the search it returns nothing? 'Microsoft Office' is not a program shortcut, its a folder name "Sebastian Trandafir" <SebastianTrandafir@xxxxxx> wrote in message news:1F54612C-24FC-4B30-92CE-9BA972613D91@xxxxxx Quote: > there is this small frustration i'm having with Vista's Search option. > > I am using Vista Home Premium [32b] [NO Service Pack installed], and there > is some time now since some of my programs wouldn't open using this neat > method Vista implemented introducing the "Search" field in the Start Menu. > > This does not happen to all the programs i have installed. It only happens > with Microsoft Office and iTunes [sadly, i use these two quite a lot]. In > the > past, i have tried reinstalling the applications, working on the Search > Index... everything seems to be alright, but, somehow there are some > broken > links that i can't figure. The search is successful, the program name is > being offered as a result, but the program won't start when i hit "enter". > nor when i right click on it and select "Open". > > I would really appreciate some help on the matter. > Yours, Sebastian. |
| | Re: Problems starting programs using Start/Search Field/Program Name after a while since i posted the question... i found the resolution. thank you all for bugging me about the SP1 install... in the end i had to do it. i reinstalled Windows Vista, and then SP1 worked like a charm. the start/search field/program name problem is now gone, i can finally use this function as desired [i know, loads of you don't necessarly agree with this way of using the function]. what else can i say? just thanks a bunch for all of your replies and stuff. yours, sebastian. |
| Explorer problem on start and context menus and long starting programs | General Discussion | |||
| Program not in Start Up .. starting up! | General Discussion | |||
| one program is blocking other programs to start? | Vista account administration | |||
| WHAT PROGRAM GOVERNS THE START-UP PROGRAMS | Vista General | |||
| Program starting up, not in start up list | Vista General | |||
