| Vista Ultimate x64 | Right Click problem Hi, I am having a problem with my Vista X64 and hope if anyone can help. For sometimes now, whenever I right click on any icon on desktop or in File Manager, the action triggers Adobe Acrobat Installation program. Can anyone tell me how to fix it? Thank you very much in advance, Dzung Nguyen |
| | Re: Right Click problem troispuits wrote: Quote: > Hi, > > I am having a problem with my Vista X64 and hope if anyone can help. > For sometimes now, whenever I right click on any icon on desktop or in > File Manager, the action triggers Adobe Acrobat Installation program. > Can anyone tell me how to fix it? > > Thank you very much in advance, > > Dzung Nguyen --PA |
| Vista Ultimate x64 | Re: Right Click problem I only have an account on my system. |
| | Re: Right Click problem troispuits wrote: Quote: > > I only have an account on my system. Here's my standard boilerplate about that: **** You absolutely do not want to have only one user account. Like XP and all other modern operating systems, Vista is a multi-user operating system with built-in system accounts such as Administrator, Default, All Users, and Guest. These accounts should be left alone as they are part of the operating system structure. You particularly don't want only one user account with administrative privileges on Vista because the built-in Administrator account (normally only used in emergencies) is disabled by default. If you're running as Administrator for your daily work and that account gets corrupted, things will be Difficult. It isn't impossible to activate the built-in Administrator to rescue things, but it will require third-party tools and working outside the operating system. The user account that is for your daily work should be a Standard user, with the extra administrative user (call it something like "CompAdmin" or "Tech" or the like) only there for elevation purposes. After you create "CompAdmin", log into it and change your regular user account to Standard. Then log back into your regular account. If you want to go directly to the Desktop and skip the Welcome Screen with the icons of user accounts, you can do this the same way as in XP: Configure Windows to Automatically Login (MVP Ramesh) - http://windowsxp.mvps.org/Autologon.htm **** Now, to address your problem - The reason "Pavel A." asked if the issue arises in another user account is to try and determine if something you have running only in your account is the culprit. The problem may be system-wide, or maybe not. Very often right-click problems are caused by third-party context menu extensions. Perhaps you had an Adobe product that didn't install properly and there is a right-click context menu item from it. You can manage right-click context menu extensions easily with the free ShellExView program. Look for non-Microsoft items and disable them, testing after each change. http://www.nirsoft.net/utils/shexview.html Malke -- MS-MVP Elephant Boy Computers - Don't Panic! FAQ - http://www.elephantboycomputers.com/#FAQ |
| IE8 and double click problem | Vista General | |||
| Right click problem | General Discussion | |||
| Problem in Click once deployment | .NET General | |||
| Mouse Right Click Problem - IE7 | Vista General | |||
| I-7 & Right Click Problem | Vista General | |||
