br> br> |
| | Thread Tools | Display Modes |
| Guest | System Volume Information out of control! I have a really stupid question: What is the System Volume Information folder used for? And why does it contain 60GB of data there? Running Vista x64bit Build 6000 (RTM) RAID5 (x3 320GB) Thanks, Mike |
| Guest | Re: System Volume Information out of control! Nevermind, it turns out that it was the System Restore, I didn't realize that it could use up to 15% of your HDD space, 15% of 600GB is a lot of space and you do notice... Question is, should I turn it off? "Mike" <weapon_x22@nospam.hotmail.com> wrote in message news:837C1299-92DC-46DA-B070-FC0582743F04@microsoft.com... >I have a really stupid question: What is the System Volume Information >folder used for? And why does it contain 60GB of data there? > > Running Vista x64bit Build 6000 (RTM) > RAID5 (x3 320GB) > > Thanks, > Mike |
| Guest | Re: System Volume Information out of control! "Mike" <weapon_x22@nospam.hotmail.com> wrote in message news:20E29BD8-7193-456D-8B64-64816C381A80@microsoft.com... > Nevermind, it turns out that it was the System Restore, I didn't realize > that it could use up to 15% of your HDD space, 15% of 600GB is a lot of > space and you do notice... Question is, should I turn it off? No. |
| Guest | Re: System Volume Information out of control! 15% of 600GB is nothing in the event that you need to do a system restore "Nathanial Woolls" <nwoolls@maine.rr.com> wrote in message news:00FED793-0981-49A2-BE8A-EB331D3A06B8@microsoft.com... > "Mike" <weapon_x22@nospam.hotmail.com> wrote in message > news:20E29BD8-7193-456D-8B64-64816C381A80@microsoft.com... >> Nevermind, it turns out that it was the System Restore, I didn't realize >> that it could use up to 15% of your HDD space, 15% of 600GB is a lot of >> space and you do notice... Question is, should I turn it off? > > No. |
| Guest | Re: System Volume Information out of control! The syntax of the vssadmin command is not a lot of fun, but it does allow you to control the amount of space allocated to system restore and shadow copies. See: http://vistasupport.mvps.org/decreas...em_restore.htm "Mike" <weapon_x22@nospam.hotmail.com> wrote in message news:20E29BD8-7193-456D-8B64-64816C381A80@microsoft.com... > Nevermind, it turns out that it was the System Restore, I didn't realize > that it could use up to 15% of your HDD space, 15% of 600GB is a lot of > space and you do notice... Question is, should I turn it off? > > "Mike" <weapon_x22@nospam.hotmail.com> wrote in message > news:837C1299-92DC-46DA-B070-FC0582743F04@microsoft.com... >>I have a really stupid question: What is the System Volume Information >>folder used for? And why does it contain 60GB of data there? >> >> Running Vista x64bit Build 6000 (RTM) >> RAID5 (x3 320GB) >> >> Thanks, >> Mike > |
| | #6 (permalink) |
| Guest | Re: System Volume Information out of control! its easy to limit the amount of disk space used for restore. on the System Properties pages you can change the % allocated. mikeyhsd@sport.rr.com "Robert Blacher" <rblacher@community.nospam> wrote in message news:147FF671-3B1D-40FB-AC21-D7E726B19843@microsoft.com... The syntax of the vssadmin command is not a lot of fun, but it does allow you to control the amount of space allocated to system restore and shadow copies. See: http://vistasupport.mvps.org/decreas...em_restore.htm "Mike" <weapon_x22@nospam.hotmail.com> wrote in message news:20E29BD8-7193-456D-8B64-64816C381A80@microsoft.com... > Nevermind, it turns out that it was the System Restore, I didn't realize > that it could use up to 15% of your HDD space, 15% of 600GB is a lot of > space and you do notice... Question is, should I turn it off? > > "Mike" <weapon_x22@nospam.hotmail.com> wrote in message > news:837C1299-92DC-46DA-B070-FC0582743F04@microsoft.com... >>I have a really stupid question: What is the System Volume Information >>folder used for? And why does it contain 60GB of data there? >> >> Running Vista x64bit Build 6000 (RTM) >> RAID5 (x3 320GB) >> >> Thanks, >> Mike > |
| | #7 (permalink) |
| Guest | Re: System Volume Information out of control! I notice that Vista allows the recovery of older versions of a single non-system file -- called shadow copies. So, it that why System Restore now wants seemingly gargantuan amounts of hard disk space -- to store the journaling info for shadow copies of document files? If you need to substantially reduce the proportion of disk space allocated to system restore, would it not make sense to turn off shadow copies, first? How would you turn off shadow copies? "Robert Blacher" <rblacher@community.nospam> wrote in message news:147FF671-3B1D-40FB-AC21-D7E726B19843@microsoft.com... > The syntax of the vssadmin command is not a lot of fun, but it does > allow you to control the amount of space allocated to system restore > and shadow copies. > > See: > > http://vistasupport.mvps.org/decreas...em_restore.htm > > > "Mike" <weapon_x22@nospam.hotmail.com> wrote in message > news:20E29BD8-7193-456D-8B64-64816C381A80@microsoft.com... >> Nevermind, it turns out that it was the System Restore, I didn't >> realize that it could use up to 15% of your HDD space, 15% of 600GB >> is a lot of space and you do notice... Question is, should I turn it >> off? >> >> "Mike" <weapon_x22@nospam.hotmail.com> wrote in message >> news:837C1299-92DC-46DA-B070-FC0582743F04@microsoft.com... >>>I have a really stupid question: What is the System Volume >>>Information folder used for? And why does it contain 60GB of data >>>there? >>> >>> Running Vista x64bit Build 6000 (RTM) >>> RAID5 (x3 320GB) >>> >>> Thanks, >>> Mike >> |
| | #8 (permalink) |
| Guest | Re: System Volume Information out of control! Not in Vista! System Restore in Vista is far different than in earlier versions of Windows. Regards, Bert Kinney MS-MVP Shell/User http://bertk.mvps.org Member: http://dts-l.org mikeyhsd wrote: > its easy to limit the amount of disk space used for restore. > on the System Properties pages you can change the % allocated. |
| | #9 (permalink) |
| Guest | Re: System Volume Information out of control! you can certainly turn it off at least by unchecking it on the drive in question. mikeyhsd@sport.rr.com "Bert Kinney" <bert@NSmvps.org> wrote in message news:%23Tc9%23urKHHA.3268@TK2MSFTNGP04.phx.gbl... Not in Vista! System Restore in Vista is far different than in earlier versions of Windows. Regards, Bert Kinney MS-MVP Shell/User http://bertk.mvps.org Member: http://dts-l.org mikeyhsd wrote: > its easy to limit the amount of disk space used for restore. > on the System Properties pages you can change the % allocated. |
| | #10 (permalink) |
| Guest | Re: System Volume Information out of control! That was true in XP. Want to double-check please in Vista? "mikeyhsd" <mikeyhsd@sport.rr.com> wrote in message news:%23hNFO7qKHHA.2236@TK2MSFTNGP02.phx.gbl... its easy to limit the amount of disk space used for restore. on the System Properties pages you can change the % allocated. mikeyhsd@sport.rr.com "Robert Blacher" <rblacher@community.nospam> wrote in message news:147FF671-3B1D-40FB-AC21-D7E726B19843@microsoft.com... The syntax of the vssadmin command is not a lot of fun, but it does allow you to control the amount of space allocated to system restore and shadow copies. See: http://vistasupport.mvps.org/decreas...em_restore.htm "Mike" <weapon_x22@nospam.hotmail.com> wrote in message news:20E29BD8-7193-456D-8B64-64816C381A80@microsoft.com... > Nevermind, it turns out that it was the System Restore, I didn't realize > that it could use up to 15% of your HDD space, 15% of 600GB is a lot of > space and you do notice... Question is, should I turn it off? > > "Mike" <weapon_x22@nospam.hotmail.com> wrote in message > news:837C1299-92DC-46DA-B070-FC0582743F04@microsoft.com... >>I have a really stupid question: What is the System Volume Information >>folder used for? And why does it contain 60GB of data there? >> >> Running Vista x64bit Build 6000 (RTM) >> RAID5 (x3 320GB) >> >> Thanks, >> Mike > |
| Display Modes | |
| System Volume Information | t-4-2 | Vista performance & maintenance | 9 | 08-03-2008 08:28 PM |
| System Volume Information | Bogdan | Vista security | 2 | 01-10-2008 11:58 PM |
| System Volume Information | jmjprince | Vista hardware & devices | 3 | 01-01-2008 10:20 AM |
| Need to fix System Volume Information | Searinox | Vista security | 2 | 07-04-2007 03:08 AM |
| 43 GB System File in System Volume Information on 160 GB partition | Brent | Vista General | 6 | 04-14-2007 05:33 PM |
