Vista to XP wireless network problem
  1. #1
    brian Guest
    Hello All: I have a wireless router that is wired to one computer with
    xp on it and connects wireless to a laptop that's running Vista.
    Connects fine - both access internet no problems. The problem is with
    sharing files between the two comps. I thought that it was xp not
    talking to Vista so I took the laptop to the router and wired it up and
    both machines can see and share and copy back and forth. Same thing when
    both are connected wireless to the router. But when the Vista machine is
    connected wireless it can see the xp machine when wired (in an explorer
    window), can see the folders that are shared, but can only open the
    Windows shares, not the data folders I want to share. It won't copy
    anything from xp to Vista. From xp I can see and open and change text
    files, but if I try to copy anything large (300megs) it gives a 'network
    location is no longer available' error. I used to do this with two xp
    machines and the same router (Comtrend) with exact same configuration.
    But since I have the Vista machine wireless it won't work. Do I have a
    router config. or network card config problem? I don't know enough to
    troubleshoot this, I fiddle with configs. but so far haven't got
    anywhere. Could someone offer some ideas, please?
    Thanks
    b
  2. #2
    Rock Guest
    Re: Vista to XP wireless network problem
    "brian" <thefergies@inicia.dot.es> wrote
    > Hello All: I have a wireless router that is wired to one computer with xp
    > on it and connects wireless to a laptop that's running Vista. Connects
    > fine - both access internet no problems. The problem is with sharing files
    > between the two comps. I thought that it was xp not talking to Vista so I
    > took the laptop to the router and wired it up and both machines can see
    > and share and copy back and forth. Same thing when both are connected
    > wireless to the router. But when the Vista machine is connected wireless
    > it can see the xp machine when wired (in an explorer window), can see the
    > folders that are shared, but can only open the Windows shares, not the
    > data folders I want to share. It won't copy anything from xp to Vista.
    > From xp I can see and open and change text files, but if I try to copy
    > anything large (300megs) it gives a 'network location is no longer
    > available' error. I used to do this with two xp machines and the same
    > router (Comtrend) with exact same configuration. But since I have the
    > Vista machine wireless it won't work. Do I have a router config. or
    > network card config problem? I don't know enough to troubleshoot this, I
    > fiddle with configs. but so far haven't got anywhere. Could someone offer
    > some ideas, please?
    You would be better off posting to the
    microsoft.public.windows.vista.networking_sharing newsgroup.
    Rock [MS-MVP User/Shell]
Vista to XP wireless network problem problems?
Vista Wireless Network Problem cmno Network & Sharing 1 01 Apr 2009
Problem with Network printer over wireless network. Russ Vista print fax & scan 1 30 Oct 2007
Problem with Vista & multiple wireless network ports Neil Gould Vista networking & sharing 2 10 Sep 2007
Problem adding wireless network, Vista RTM WPA2-PSK, no SSID broad Cecil Ward Vista networking & sharing 5 24 Apr 2007
Network Printer and Wireless Network problem Jim Vista installation & setup 1 07 Mar 2007
