Go Back   Vista Forums > Vista Newsgroups > Vista file management
Vista - Problem using Low Power State
Old 07-15-2007   #1 (permalink)
Windows Vistax64
Hello,
I have just two days ago bought or rather had a brand new system built, its an Intel Core 2 Duo, and the problem I have is that when I put the system into the low power state, the Monitor goes off, but I then hear this persistant loud infact piercingly loud high pitched noise coming from the PC, only way I could stop it was to switch off at the mains, not something I like to do of course.
When I switch on again the system boots fine, no problem, its just when using this low-power state, its a feature I guess I could live without, but in all honesty, I would like to be able to use it instead of having to turn the Computer on and off when I am going to be going back to it an hour or so later.
Does anyone here know anything about this or can help in some way please..........I am new to Vistax64 and love my new system, but this is something that is niggling away at me at the moment.
I hope this is not in the wrong place, so sorry if it is
Many thanks
BlueNightmare
Old 07-15-2007   #2 (permalink)
Malke
Re: Problem using Low Power State
BlueNightmare wrote:
> Hello,
Since you had the machine built for you, I think I'd contact the
builder. It sounds like a fan going on and no fan should do that.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Old 07-15-2007   #3 (permalink)
Windows Vistax64
Yes I guess that's best, not something I wanted to have to do I must admit as its all brand new, but then again my luck dictates bad things all the time!! lol
Thanks anyway, I appreciate your opinion
BlueNightmare
Low power state not working Vista General
low power state Vista General
USB Hub power state NOT sticking Vista hardware & devices
low power state Vista performance & maintenance
Shut down VS 'low power state' Vista General
