| | Registry location for Right Click Start Menu I had the registry locations in XP of the "Right Click Start Menu" so I could establish the "Explore" and "Explore All" folder location(s) to which they would default, other than the "Start Menu." I am unable to locate the ROOT location for these entries in Vista, as I wish both to change the default folder and remove a McAfee "Scan" shortcut that has somehow been added to this "Right Click Start Menu" without my interaction. I know how to change the "Explorer Shortcut," but I don't use it much and don't wish to add directive "shortcuts" into my Quick Start area. I use the all of the "Right Click" menus most of the time and don't wish the default to go to the "Start Menu" folder, but the specific folder that I designate. Please advise the ROOT location for these entries. Thank you! |
| | Re: Registry location for Right Click Start Menu Manage the context-menu entries for files, folders, drives and Namespace objects: http://windowsxp.mvps.org/context_folders.htm <Q> The context-menu entries for Directories is built from these locations in the registry. The same applies for the Start button in the Taskbar </Q> -- Regards, Ramesh Srinivasan, Microsoft MVP [Windows Shell/User] Windows® Troubleshooting http://www.winhelponline.com "mbscjohnp" <mbscjohnp@discussion.microsoft.com> wrote in message news:4BF2987D-5FEB-4602-B685-06FBDED31DA5@microsoft.com... I had the registry locations in XP of the "Right Click Start Menu" so I could establish the "Explore" and "Explore All" folder location(s) to which they would default, other than the "Start Menu." I am unable to locate the ROOT location for these entries in Vista, as I wish both to change the default folder and remove a McAfee "Scan" shortcut that has somehow been added to this "Right Click Start Menu" without my interaction. I know how to change the "Explorer Shortcut," but I don't use it much and don't wish to add directive "shortcuts" into my Quick Start area. I use the all of the "Right Click" menus most of the time and don't wish the default to go to the "Start Menu" folder, but the specific folder that I designate. Please advise the ROOT location for these entries. Thank you! |
| User Start Menu Location | Vista General | |||
| Shortcut from Start Menu changes location | Vista General | |||
| Right-click item in Start Menu = Explorer crash | Vista General | |||
| Right-click item on start menu = explorer crash | Vista General | |||
| Vista Start menu location weirdness | Vista installation & setup | |||
