Go Back   Vista Forums > Vista Newsgroups > Vista file management
Vista - problem when using dvd data backup disk made with XP in Vista
Old 09-30-2007   #1 (permalink)
John L.
When I put in a DVD Data Disk that I made in Windows XP into my Vista
laptop, I noticed that when using Windows Explorer in Vista 90% of the files
were not showing on the DVD disk !!! What am I doing wrong? Why can't I see
the rest of the files? None of these files are hidden in XP. I have Vista
set to show all files. There were no error messages when using the DVD Disk.
I even tried turning off UAC in Vista, but no more files were visible.
Anyone know why I can't see the rest of the files?
Old 10-02-2007   #2 (permalink)
hlwenger
RE: problem when using dvd data backup disk made with XP in Vista
Vista comes with Roxio 9 basic. It is not always compatible with the Roxio
programs you paid for such as Roxio Easy CD Creator 8 (for example).
What I did was to delete the basic rox 9 and install the full version of 8
on my vista machine. It worked.
Help restoring a backup made with Roxio BackupMyPC 7 Software
USB Flash Disk access problem; Vital Data at Stake =[ Vista hardware & devices
Problem when using dvd data backup disk made with XP in Vista Vista General
Have anyone successfully restored an disk image made with Windows Backup on Vista? Vista General
Cannot restore a backup made with recovery manager on vista Vista General
