| Vista Home Premium 32bit | Fixing problems with Neverwinter Nights 2 on Vista Home Premium 32bit I just bought NWN 2 last night and installed it, no problems. My laptop met or exceeded the minimum requirements. However, I start to run it, and it comes up with an error saying that I have no compatible Direct3D device. What does this mean? I updated it completely, that didn't fix the problem. I have Vista Home Premium 32bit, if that helps. Any ideas? |
| | Re: Fixing problems with Neverwinter Nights 2 on Vista Home Premium 32bit This sounds as though your video adapter in yor laptop is not up to specs. It is possible that you haven't dedicated enough Video Memory to the adapter in Windows or via the Bios. Try increasing the memory for your adapter through the Display Adapter Control Panel or through your BIOS. That may fix the problem. "mwmike11" <mwmike11.31wlu6@xxxxxx-mx.forums.net> wrote in message news:mwmike11.31wlu6@xxxxxx-mx.forums.net... Quote: > > I just bought NWN 2 last night and installed it, no problems. My laptop > met or exceeded the minimum requirements. However, I start to run it, > and it comes up with an error saying that I have no compatible Direct3D > device. What does this mean? I updated it completely, that didn't fix > the problem. I have Vista Home Premium 32bit, if that helps. Any ideas? > > > -- > mwmike11 |
| Neverwinter Nights 2 problems | Gaming | |||
| neverwinter nights 1 patch | Vista Games | |||
| Neverwinter Nights 2 Installation | Vista Games | |||
| Neverwinter Nights 1 | Vista Games | |||
| Neverwinter Nights (Diamond) | Vista Games | |||
