| | Vista - Big Problems running Sims 2 on Vista Home Premium |
| 07-09-2008 | #1 |
| | Big Problems running Sims 2 on Vista Home Premium Your Open QuestionShow me another » The SIMS 2 (for PC) and New VISTA laptop? My Sims 2 CD works fine on my old laptop. I checked on systemrequirementslab.com and it said that my computer PASSED for all of the requirements, both minimum and reccomended. I downloaded the patch from Maxis. The computer no longer says there are compatibility problems... HOWEVER, I load the game, get to the neighborhood, and then click on a family - it never loads. The music just goes and goes and goes, then I press ctrl+alt+delete and it says that the program is not responding. Also, when I change the game settings it sometimes freezes. Help? Additional Details - I have PLENTY of room for the program on my computer. - I have tried the compatibility option "run compatibility with Windows XP" as suggested in a similar question - The disc is in great shape - I have a DELL Inspiron 1525 - I have Vista Home Premium I have also tried "running as an administrator" - no luck. Same exact problem! |
| 07-20-2008 | #2 |
| | RE: Big Problems running Sims 2 on Vista Home Premium "technologicallyimpaired" wrote: Quote: > Your Open QuestionShow me another » > > The SIMS 2 (for PC) and New VISTA laptop? > My Sims 2 CD works fine on my old laptop. > I checked on systemrequirementslab.com and it said that my computer PASSED > for all of the requirements, both minimum and reccomended. > I downloaded the patch from Maxis. > The computer no longer says there are compatibility problems... HOWEVER, > > I load the game, get to the neighborhood, and then click on a family - it > never loads. The music just goes and goes and goes, then I press > ctrl+alt+delete and it says that the program is not responding. > > Also, when I change the game settings it sometimes freezes. > > Help? > > Additional Details > > - I have PLENTY of room for the program on my computer. > - I have tried the compatibility option "run compatibility with Windows XP" > as suggested in a similar question > - The disc is in great shape > - I have a DELL Inspiron 1525 > - I have Vista Home Premium > > I have also tried "running as an administrator" - no luck. Same exact problem! > I had the same problem. Many online forums blame the integrated Intel video card. But I wasn't satisfied with that explanation as Sims2 ran fine on older laptops I had. After trying EVERYTHING, including Sims2 sw patches, video driver updates, etc. as a last test I simply blew away Vista and installed Windows XP. I was happy to find out the the Dell Inspiron 1525 runs Sims2 GREAT with XP, the problem isn't the laptop, isn't the video card, its VISTA. My advice, ditch Vista and go with XP.... |
| 07-20-2008 | #3 |
| Vista Home Premium x64 SP1 | Re: Big Problems running Sims 2 on Vista Home Premium "technologicallyimpaired" wrote: Quote: > Your Open QuestionShow me another » > > The SIMS 2 (for PC) and New VISTA laptop? > My Sims 2 CD works fine on my old laptop. > I checked on systemrequirementslab.com and it said that my computer PASSED > for all of the requirements, both minimum and reccomended. > I downloaded the patch from Maxis. > The computer no longer says there are compatibility problems... HOWEVER, > > I load the game, get to the neighborhood, and then click on a family - it > never loads. The music just goes and goes and goes, then I press > ctrl+alt+delete and it says that the program is not responding. > > Also, when I change the game settings it sometimes freezes. > > Help? > > Additional Details > > - I have PLENTY of room for the program on my computer. > - I have tried the compatibility option "run compatibility with Windows XP" > as suggested in a similar question > - The disc is in great shape > - I have a DELL Inspiron 1525 > - I have Vista Home Premium > > I have also tried "running as an administrator" - no luck. Same exact problem! > card. But I wasn't satisfied with that explanation as Sims2 ran fine on older laptops I had. After trying EVERYTHING, including Sims2 sw patches, video driver updates, etc. as a last test I simply blew away Vista and installed Windows XP. I was happy to find out the the Dell Inspiron 1525 runs Sims2 GREAT with XP, the problem isn't the laptop, isn't the video card, its VISTA. My advice, ditch Vista and go with XP.... To the OP: Try this link. SIMS 2 |
| 07-22-2008 | #4 |
| | Re: Big Problems running Sims 2 on Vista Home Premium "FrozenEclipse" wrote: Quote: > > simplifyme;781891 Wrote: Quote: > > "technologicallyimpaired" wrote: Quote: > > > > > > > > > Your Open QuestionShow me another » > > > > > > > > The SIMS 2 (for PC) and New VISTA laptop? > > > > My Sims 2 CD works fine on my old laptop. > > > > I checked on systemrequirementslab.com and it said that my computer > > > PASSED > > > > for all of the requirements, both minimum and reccomended. > > > > I downloaded the patch from Maxis. > > > > The computer no longer says there are compatibility problems... > > > HOWEVER, > > > > > > > > I load the game, get to the neighborhood, and then click on a family > > > - it > > > > never loads. The music just goes and goes and goes, then I press > > > > ctrl+alt+delete and it says that the program is not responding. > > > > > > > > Also, when I change the game settings it sometimes freezes. > > > > > > > > Help? > > > > > > > > Additional Details > > > > > > > > - I have PLENTY of room for the program on my computer. > > > > - I have tried the compatibility option "run compatibility with > > > Windows XP" > > > > as suggested in a similar question > > > > - The disc is in great shape > > > > - I have a DELL Inspiron 1525 > > > > - I have Vista Home Premium > > > > > > > > I have also tried "running as an administrator" - no luck. Same exact > > > problem! > > > > > > I had the same problem. Many online forums blame the integrated Intel > > card. But I wasn't satisfied with that explanation as Sims2 ran fine > > on older > > laptops I had. > > > > After trying EVERYTHING, including Sims2 sw patches, video driver > > updates, > > etc. as a last test I simply blew away Vista and installed Windows > > XP. I was > > happy to find out the the Dell Inspiron 1525 runs Sims2 GREAT with > > XP, the > > problem isn't the laptop, isn't the video card, its VISTA. > > > > My advice, ditch Vista and go with XP.... > Then you're giving him bad advice. There's absolutely no reason to use > XP over Vista if your computer can handle Vista. > > To the OP: Try this link. > > SIMS 2 > > > -- > FrozenEclipse > Thanks to you both for your suggestions - I can't seem to find a specific update that is a fix for Vista... The Sims2 patch did nothing - and I really can't change operating systems - too much of a hassle and $$$ (as you can't downgrade for 'free' if you have vista home as far as I know)... Plus I like Vista as far as everything else is concerned - and I suppose the Sims 2 isn't a priority. Is there any link for this update - or what should I be looking for? P.S. I'm a "her". Haha. |
| 07-23-2008 | #5 |
| | Re: Big Problems running Sims 2 on Vista Home Premium =?Utf-8?B?dGVjaG5vbG9naWNhbGx5aW1wYWlyZWQ=?= <technologicallyimpaired@xxxxxx> wrote in news:E448D58C-B84E-4FFF-852D-FA6FAD6E6B95@xxxxxx: Quote: > Thanks to you both for your suggestions - I can't seem to find a > specific update that is a fix for Vista... The Sims2 patch did nothing > - and I really can't change operating systems - too much of a hassle > and $$$ (as you can't downgrade for 'free' if you have vista home as > far as I know)... Plus I like Vista as far as everything else is > concerned - and I suppose the Sims 2 isn't a priority. Is there any > link for this update - or what should I be looking for? > > P.S. I'm a "her". Haha. that states if you don't agree to the Vista License agreement, you can install another OS and get a "refund" for Vista. I read an article somewhere that some guy got HP to cough up $200. I think it was theconsumerist.com, but it took a lot of effort and bitching to get them to cough it up. There is no update specifically for Vista for The Sims 2, If you have the latest patch from the Sims 2 website, everything should be right as rain. The only thing The Sims 2 site suggests is updating video card drivers. The problem with the "compatibility checks" (I'm not sure what check you are using, but...) is that sometimes the checks are based on old hardware. With the new hardware it just assumes you're OK, but sometimes you can't go on that information alone. Dispite what people said earlier, it'd be best to check your drivers again. Since you listed your computer, I can now look up your video card and do most of the legwork for ya... dell.com/support - says you have an Intel GM965 chipset/video. So instead of downloading that driver from Dell, lets get the one from Intel, it tends to be more up to date... http://downloadcenter.intel.com/default.aspx - Found your chipset/driver by going to this link and selecting from the left menu... Graphics > Laptop > Express 965 chipset... or something to that effect. First file link takes you here: http://tinyurl.com/66eu8a Download that file and run it on your system, hey you now have the latest video driver for your computer. joy. I believe this also covers all your other Intel system drivers. Joy joy! Try the game again. Still busted? Go into your Documents folder and the EA Games folder, RENAME (don't delete) The Sims 2 Save games folder to something like The Sims 2.bak, that takes your current saves out of the picture. Run Sims 2 again, it'll take a long time to boot this time because it's gonna reset all your save files. And see if you can get into a house now. Sorry you're having so many problems. Try running the game as admin, or if it's really killing you, turn off UAC (in the User Accounts control panel), for now. -- -A. |
| 08-10-2008 | #6 |
| | Re: Big Problems running Sims 2 on Vista Home Premium I have just got a new lap top too (with Vista 32 bit) and have had big problems installing and running Sims 2. I read that Windows Vista Firewall could be the problem. So I added the game to the Firewall exceptions list. Doing this and also right clicking on the desktop shortcut to open Sims 2 and selecting "run as administrator" has the game working properly. It's a fairly simple fix - but worth a try if you haven't done it. "technologicallyimpaired" <technologicallyimpaired@xxxxxx> wrote in message news:18798FE5-0397-45E1-A595-AA25E9355E10@xxxxxx Quote: > Your Open QuestionShow me another » > > The SIMS 2 (for PC) and New VISTA laptop? > My Sims 2 CD works fine on my old laptop. > I checked on systemrequirementslab.com and it said that my computer PASSED > for all of the requirements, both minimum and reccomended. > I downloaded the patch from Maxis. > The computer no longer says there are compatibility problems... HOWEVER, > > I load the game, get to the neighborhood, and then click on a family - it > never loads. The music just goes and goes and goes, then I press > ctrl+alt+delete and it says that the program is not responding. > > Also, when I change the game settings it sometimes freezes. > > Help? > > Additional Details > > - I have PLENTY of room for the program on my computer. > - I have tried the compatibility option "run compatibility with Windows > XP" > as suggested in a similar question > - The disc is in great shape > - I have a DELL Inspiron 1525 > - I have Vista Home Premium > > I have also tried "running as an administrator" - no luck. Same exact > problem! > |
Similar Threads for: Big Problems running Sims 2 on Vista Home Premium
| Running Vista Home Premium | Vista hardware & devices | |||
| Vista home premium x64 running slow | General Discussion | |||
| Sims 1 and Vista Home Premium | Vista Games | |||
| Running PC DJVJ on Vista Home Premium | Vista music pictures video | |||
| Running EyeballChat with vista home premium | Vista General | |||
