Go Back   Vista Forums > Vista Newsgroups > Vista Games
Vista - Counter-Strike connection problem
Old 03-13-2009   #1 (permalink)
Vista Ultimate x64
Hi, new to the forum and dont have much computer experience. But im having this problem for Counter-Strike 1.6. I've downloaded steam and got all the updates. When I try to connect to a server to play, the box would show "Establishing connection to network server.." with 3 bar and froze. The only way out would be Ctrl+Alt+Del and End Task.
At first, I thou it was Windows Firewall and the router. After I've disable both, still no luck.
A friend is having the same issue and hes also running Vista x64.
Please help as I tried many times and many different methods.
My spec, Intel Core i7, Evga X58, EVGA GTX 285.
Thanks.
Old 03-15-2009   #2 (permalink)
Vista Ultimate x64
Re: Counter-Strike connection problem
There seems to be a known problem with Steam client and Valve games caused by Linksys routers.
Add this parameter to each game you're playing: CS: Source, DOD: Source etc.
Right click on the game, select Properties from the context menu. Once in properties window click on [Set launch options...] button.
Launch options window will appear. Enter the following value:
+clientport 27006
Save it.
Now it should work...
Old 03-17-2009   #3 (permalink)
Vista Ultimate x64
thanks!
I hope this will resolve my problem. Will give it a try tonight.
Old 03-18-2009   #4 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by vnvnvn2000 View Post
+clientport 27006
Save it.
What do u mean? I got kinda confuse on the instructions.
I tried to add +clientport 27006 behind the Start In behind the quote. No luck there
Old 03-18-2009   #5 (permalink)
ianwvt
Quote:
> I tried to add +clientport 27006 behind the *Start In* behind the
> tonyx614
You can also try going to your router config page and see if there is
an option to open ports. On my router there is an option to open
gaming ports - I just need to pick the game from a dropdown box (in a
section called "Assigned Games & Applications") and click add. In this
case, I added "Half Life 2" to the list and it works... as CS:S is
based on the HL2 engine and uses the same ports:
UDP : 27000 - 27015
TCP : 27030 - 27039
____________________
Ian
Windows Vista Tips - http://www.winvistatips.com
Old 03-18-2009   #6 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by ianwvt View Post
> tonyx614
UDP : 27000 - 27015
TCP : 27030 - 27039
Ian
Windows Vista Tips - Windows Vista Tips
I tried to port to the listed ports but still no luck. I have almost tried the DMZ and still cant. The router is a D-Link 655.
I have a friend who is using Vista 64 and we both cant get pass this screen here.
Old 03-23-2009   #7 (permalink)
Vista Ultimate x64
any suggestion, anyone?
Old 03-24-2009   #8 (permalink)
Olórin
tonyx614 wrote:
Yup - don't snip out all of a thread's previous history. You're talking into
empty space.
A counter strike 1.6 problem Gaming
Problem Counter-Strike Graphic cards
Counter Strike Source problem Gaming
counter strike servers problem Vista General
Re: Counter Strike Source and UT 2004 Slow Server Connection Issues Vista Games
