Go Back   Vista Forums > Vista Newsgroups > Vista Games
Vista - PES6 Problem With Vista PLZ HELP
Old 04-07-2009   #1 (permalink)
Vista
Hi every Body
i'm new to this forum. i have pes6 on my pc i have windows XP it is working well it's hard copy(i havn't installed it just open the reg. file and and open game it works) two of my friends took the game fom me the have windows vista it doesn't work at any one of them and gives the same error.so plz if any one know how to make it work plz tell me.there is a patch in the game for egyptian league i havn't installed it it comes with it when took it from another friend so if this patch is causing that problem so help me to remove it or download another patch that make it work on vista.
one other thing i want plz i want a link for 2009 transferes for PES6 if it's available.
here is a picture about the error appears on Vista's PC:
Old 04-07-2009   #2 (permalink)
EN4CER
Re: PES6 Problem With Vista PLZ HELP
Joe this is for you man:
http://lmgtfy.com/
LMFAO
ie: "I can't get widescreen to work in BF2142."
Response:
http://lmgtfy.com/?q=widecreen+in+bf2142
EN4CER
"Haitham" <guest@xxxxxx-email.com> wrote in message
news:4c9b40b5ae0d22a6206aba26823e1d44@xxxxxx-gateway.com...
Quote:
> Hi every Body
> if it's available.
> [image: http://img14.imageshack.us/img14/3479/64059664.jpg]
> Haitham
Old 04-08-2009   #3 (permalink)
Vista
thanks these site is really usefull i wish i could find the solution there.
but do u know how can i remove Kit server from the game i think it is the cause of the problem
PES6 Not Working on Vista.PLZ HELP Gaming
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Can you use XBOX 360 Controller to play PES6 on VISTA? Vista Games
Vista Sleep Problem / Network Problem Vista networking & sharing
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
