Go Back   Vista Forums > Vista Newsgroups > Vista Games
Vista - Baattlefield 2142 Sound Issue
Old 01-05-2007   #1 (permalink)
Father Fury
Quick synopsis:
Sound Issue in Battlefield 2142 with both 1.06 & 1.10 patches.
Using RC1 on a separate hard drive (dual boot to XP or Vista.) Displays fine
and worked great for a while with USB (Plantronics Gamecom Pro 1) headset
with or without Ventrilo running but at some point (not sure exactly when,
had an attitude and went back to XP so I could play) sound stopped working in
game only.
Ventrilo still works great but in 2142, no music, no nothing..
So tried without Vent running after a hard boot and nothing. I've changed
and put back quite a few settings but nothing has helped.
I'm running in Full Administrator mode, I turned UAC off since I'm the only
user.
Am I going to have to go the uninstall/reinstall route? Should I kill RC1
and start fresh? Any ideas are appreciated!
(Oh compatibility mode crashes, says I need to install the disk I just
launched the program from!)
Old 01-06-2007   #2 (permalink)
stuart richards
Re: Baattlefield 2142 Sound Issue
go to the options section and then audio. when it comes up there will prob
be some gobbledygook - ignore that and look for the default button. click
that and it "should" sort it. If not you may have to do what i did last time
and exit the game goto device manager and remove the sound card and its
software, then reinstall it and that in theory should sort it. I have had to
both in the past - but only with XP not vista.
btw you may be best off restarting windows after removing the sound card
from device manager so it wipes everythng from active memory
"Father Fury" <Father Fury@discussions.microsoft.com> wrote in message
news:4C8A28A3-E622-4245-9E53-BC675AF650CE@microsoft.com...
> Quick synopsis:
> fine
> in
> game only.
> only
> user.
Old 01-07-2007   #3 (permalink)
Father Fury
Thanks - Solved by Deleting Plantronics Headset then refreshing. After it
reloaded the drivers - All is Good!
Old 01-07-2007   #4 (permalink)
stuart richards
glad to help mate!
Happy new year in bf2142 - if uyou see "[UKE]ChaosUKE83" on the opposite
team feel free to NOT kill me at least once to return the favour
j/k see you on the battlefield sometime prob.
Stu
"Father Fury" <FatherFury@discussions.microsoft.com> wrote in message
news:C636786B-5B90-4162-BAD2-BBE1E0C9F88B@microsoft.com...
2142 & Punkbuster issue Gaming
Sound issue Vista music pictures video
Vista Sound Issue Vista General
EA LINK compatibility issue? (Battlefield 2142) Vista Games
suround sound issue Vista General
