| | Need help.. eq2, nwn2, MMO's in general i am having a hell of a time getting any of my MMO's to install correctly or run once they are installed.. 1. EQ2 i get the same error.. "LP_plugin.exe has stopped running" and the newest issue is as soon a i get logged in i get the error messsage that the launcher has stopped running. once in game.. if i stay in the same area and go thru no transitions.. im ok.. but if i hit one transition it dumps the game.. 2. NWN2.. can play solo just fine.. so far.. but cannot connect to any servers online.. at all.. keeps timing out.. i am in the process of trying to load DDO and lotr and vanguard.. so far vanguard is the only one that hasnt given im install problems.. i have noticed that on any of them if you dont install and run the game as administrator.. they will not work at all.. anyway.. pretty frustrated here.. so if someone has a clue.. would apreciate some help.. i tried customer support.. but all that got me was 2 hours on hold and then when i got some one they disconnected me ![]() |
| | RE: Need help.. eq2, nwn2, MMO's in general LP_plugin.exe is a known error, and not anything to worry about. What it is designed to do, is send system configuration information to sony. Due to the security features inbeded in to Vista, the launch pad plugin does not have access to this information, so will time/error out. Something I have noticed with the betas, and RC1, is that you really can't run eq2 without rightclicking on the .exe file, or shortcut and selecting <Run as administrator>. In my expierence, strange things happen unless you do this. A member of the Everquest 2 test server comunity since its inception. A major part of the problem being that everquest tries to lock down as much resources as it can, in the old windows fashion that led to bsod's, which vista doesn't like. I know for a fact that the eq2 team is working on this, but I wouldn't expect a vista specific update for atleast a couple more months. Your zoning issues are strange tho. Nothing I have heard about from any of the other testers using Vista, makes me wonder if this is a driver specific issue, trying to unload system resources from memory, and the graphics sub system, and and error code lockout, timing out the game. I know that on zone, for a second or two I will get a screenie of the last frame the opening video was on before i clicked thru it, and zone loading has taken longer lately, but that is being worked on. One bit of strangeness for me tho, I run a dual boot between x86 and x64, eq installed thru the x86 version, and eq2 actually seems to work better on vista x64 then x86. With NWN2, all I can say is, Make sure that you either 1. have vistas firewall turned off, or 2. Have neverwinter nights added to the access list, otherwise you WILL only get timeouts. Welcom to the realm of the early adopter. Until next month, very few customer service locations will help you with vista. The OFFICIAL release being January 29th, even tho there ARE places you can get it from now, most places will still claim beta, and either laugh and hang up the phone or tell you to call back in a month if you still have the same problems. "Strega" wrote: > i am having a hell of a time getting any of my MMO's to install correctly or > run once they are installed.. > > 1. EQ2 i get the same error.. "LP_plugin.exe has stopped running" and > the newest issue is as soon a i get logged in i get the error messsage that > the launcher has stopped running. once in game.. if i stay in the same area > and go thru no transitions.. im ok.. but if i hit one transition it dumps the > game.. > 2. NWN2.. can play solo just fine.. so far.. but cannot connect to any > servers online.. at all.. keeps timing out.. > > i am in the process of trying to load DDO and lotr and vanguard.. so far > vanguard is the only one that hasnt given im install problems.. > > i have noticed that on any of them if you dont install and run the game as > administrator.. they will not work at all.. > > anyway.. pretty frustrated here.. so if someone has a clue.. would > apreciate some help.. i tried customer support.. but all that got me was 2 > hours on hold and then when i got some one they disconnected me ![]() |
| | RE: Need help.. eq2, nwn2, MMO's in general oh, something else,.. I have witnessed a couple of occurances where even tho the launch pad plugin pops up an error saying that it has stopped working and asks to be closed, it is still running according to task manager and using up quite a bit of system resources. Until vista has been out a while, and sony has had time to catch up. It would probably be a good idea to hit task manager and make sure that things aren't running that shouldn't be. somehow I had 2 occurances of LP_Plugin.exe running each taking between 30-40% cpu usage and leaving very little for everquest.exe "Strega" wrote: > i am having a hell of a time getting any of my MMO's to install correctly or > run once they are installed.. > > 1. EQ2 i get the same error.. "LP_plugin.exe has stopped running" and > the newest issue is as soon a i get logged in i get the error messsage that > the launcher has stopped running. once in game.. if i stay in the same area > and go thru no transitions.. im ok.. but if i hit one transition it dumps the > game.. > 2. NWN2.. can play solo just fine.. so far.. but cannot connect to any > servers online.. at all.. keeps timing out.. > > i am in the process of trying to load DDO and lotr and vanguard.. so far > vanguard is the only one that hasnt given im install problems.. > > i have noticed that on any of them if you dont install and run the game as > administrator.. they will not work at all.. > > anyway.. pretty frustrated here.. so if someone has a clue.. would > apreciate some help.. i tried customer support.. but all that got me was 2 > hours on hold and then when i got some one they disconnected me ![]() |
| is there any decent online MMO's? | Gaming | |||
| please help! trouble with nwn2 | Gaming | |||
| General | Vista General | |||
| general | Vista General | |||
