Go Back   Vista Forums > Vista Newsgroups > Vista Games
Vista - using two of the same programs at once
Old 04-22-2007   #1 (permalink)
rayray135
im trying to plac two programs of DAoC but when i conect the second one it
makes the first one go link dead of the internet how do i fix this i would
like to use both my characters at once...(vista)
Old 04-23-2007   #2 (permalink)
rayray135
RE: using two of the same programs at once
ALSO i have to alt tab between them this might be what makes me go link dead
if there is a whay to fix that alt tab problem...
« checkers | 4554 »
Help! Vista Premium x64 suddenly not loading programs on startup and no programs run! General Discussion
Solved programs folder within all programs list General Discussion
Uninstalling Programs not in Windows Features or Programs & Featur Vista General
Adding new programs to Default Programs list Vista General
uninstalling programs that are not listed in programs and features Vista General
