problem opeing cheatengine(cheatengine.org)
  1. #1
    \ Guest
    ok im having trouble getting cheatengine to work the creator(along with
    others) said for it to work on vista said you need to get class 3 id
    certificate to sign the drivers so it will work whos dumbass idea was this i
    relize it was to help protect agest virus but give us the fricking option to
    turn it off if you ask me its retarded we have to this to use programs that
    arent signed
  2. #2
    Paul Smith Guest
    Re: problem opeing cheatengine(cheatengine.org)
    "\" <\@discussions.microsoft.com> wrote in message
    news:183424B3-585A-4359-BCCF-DD2C82CB0E43@microsoft.com...
    > i
    > to
    > that
    > arent signed
    Windows Vista 32-bit doesn't require signed drivers. I'll assume you're
    using 32-bit as that is the most common. What problems are you having when
    it attempts to install the drivers?
    Paul Smith,
    Yeovil, UK.
    Microsoft MVP Windows Shell/User.
    http://www.windowsresource.net/
    *Remove nospam. to reply by e-mail*
  3. #3
    \ Guest
    > > i
    > > to
    > > that
    > > arent signed
    > Paul Smith,
    > Yeovil, UK.
    > im not trying to install it here is a post on why it wont work from someone on the forums for it"And you can run the UCE but the driver will not work properly because you can't hook the kernel, alters kernel structures, it will check for CPU registers and more"
problem opeing cheatengine(cheatengine.org) problems?
the problem with ndis.sys Blue Screen of Death problem solved? liketofindoutwhy Vista General 6 24 May 2009
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Rainald Taesler Vista mail 14 17 May 2009
Generic McAfee Problem Message in Vista Problem Reports cyberbuff53 Vista performance & maintenance 0 01 Dec 2007
fixed unable to delete email problem, now I have new problem j2 Vista mail 19 29 Mar 2007
Vista Upgrade Problem - Windows Explorer Loop problem Steve S Vista installation & setup 0 27 Jun 2006
