| | Playing/CTRL double-click problem. I'm playing a game I got with my Gateway-created system, and this plane-shooter game requires me to hit CTRL repeatedly to fire blasts. But, every time I hit CTRL, a window of Internet Explorer pops up, causing eventually impossible memory problems. I didn't notice what was going on, and then I had 44 Internet Explorer windows open up. The usual way of deleting a keyboard shortcut doesn't work. How do I get rid of this one? I got this computer today, so I guess the shortcut was pre-built in to Vista. |
| Windows Vista Home Premium x64 SP1 | Re: Playing/CTRL double-click problem. Can you replicate the problem outside of the game? That could help with determining if it's actually a shortcut. My hunch is that you might also be hitting your Windows key in your rush of playing. A quick click of that with clicking would seem consistent with that, depending on what else is clicked at the same time. For example, if you have IE in your Quick Launch (let's say 3rd position), Windows+3 would launch IE. So, that might help you. |
| | Re: Playing/CTRL double-click problem. Gabek, I don't have a gateway system so I can't be sure but it could be a custom app for the gateway keyboard. They usually have one so the little extra buttons will work right. Check your control panel and any "gateway" menus/folders for a keyboard utility. Check your services (use the administrative tools menu) and look for anything relating to the keyboard. Just be sure to back up the system before doing anything drastic! Hope that helps! Mark <Gabek;-> wrote in message news:84185E45-FA09-4482-94D7-6F59C22A1F81@xxxxxx Quote: > I'm playing a game I got with my Gateway-created system, and this > plane-shooter game requires me to hit CTRL repeatedly to fire blasts. But, > every time I hit CTRL, a window of Internet Explorer pops up, causing > eventually impossible memory problems. I didn't notice what was going on, > and > then I had 44 Internet Explorer windows open up. The usual way of deleting > a > keyboard shortcut doesn't work. How do I get rid of this one? I got this > computer today, so I guess the shortcut was pre-built in to Vista. |
| IE8 and double click problem | Vista General | |||
| Enable one click instead of double click selection | Vista installation & setup | |||
| Mouse double click problem | Vista hardware & devices | |||
| Single Click Instead Of Double Click | Vista General | |||
| hot to change mouse to single click instead of double click to ope | Vista hardware & devices | |||
