Go Back   Vista Forums > Vista Newsgroups > Vista Games
Vista - Help!! Medieval Total War 2 problem
Old 08-29-2007   #1 (permalink)
kbq
Hi all
I have windows vista and have been playing MTW2 for some months on it, but
all of a sudden it froze. I had to do a hard shutdown and then I could not
open it (got the following message: "A problem has caused the program to stop
working correctly"). I uninstalled, reinstalled and still could not open it
(same message). I downloaded the "final patch" and, though I now get the new
window for starting the game, I still get the same message above when I try
to load it.
Anyone have any insights?? Please!
kbq
Old 08-29-2007   #2 (permalink)
garfield
RE: Help!! Medieval Total War 2 problem
kbq,,
tried to verify regarding to the compatability of the game the that your
trying to play,bec. there is a lot more problem regarding playing a game
using win vista
"kbq" wrote:
Quote:
> Hi all
> to load it.
> kbq
Old 08-29-2007   #3 (permalink)
kbq
Game is compatible--had been playing it for months with no problem.
"garfield" wrote:
Quote:
> kbq,,
> using win vista
> "kbq" wrote:
Quote:
> > Hi all
> > to load it.
> > kbq
Old 08-29-2007   #4 (permalink)
Vista Ultimate x64, Windows XP Pro SP2
Re: Help!! Medieval Total War 2 problem
What else you could try is uninstalling the game with the program Ccleaner. It works great a doing a clean un-install. You can get it at CCleaner - Home. Then re-install the game and apply the patch.
Medieval 2 total war Vista Games
medieval 2 total war Vista Games
Medieval II total war Gaming
Medieval 2 Total War Gaming
Medieval Total War 2 Vista Games
