| | Halo 2 on Vista Home premium system help have I have a Compaq model 2180NX with 250 G HD and 3.3 DRAM with > 2 Ghz which I installed Halo 2 on. I have not installed a graphics card yet. The Vista system experience lowest rating is 3.0 on memory (video?) and the game will not work. I assume I need a graphics card. I have never used a graphics card. My system has 3 PCI & 1 PCIe slots empty. I have seen the notes about using a nvidia 6100 or ATI 700 or higher card on the game site. I have been looking for these cards on line and in store but been too suceessful. Are these card numbers old or there newer numbers? What should I look for? Lokking to spend under $200-$250. Looking on the Nividia & ATI sites do not give any understandable road maps. Any help or leads would be helpful. |
| | Re: Halo 2 on Vista Home premium system help "DIGITALGOST20" <DIGITALGOST20@xxxxxx> wrote in message news:684F8D37-1870-4AEF-ABA6-8AFE8722FA66@xxxxxx Quote: > have I have a Compaq model 2180NX with 250 G HD and 3.3 DRAM with > 2 Ghz > which I installed Halo 2 on. I have not installed a graphics card yet. The > Vista system experience lowest rating is 3.0 on memory (video?) and the > game > will not work. I assume I need a graphics card. I have never used a > graphics > card. My system has 3 PCI & 1 PCIe slots empty. I have seen the notes > about > using a nvidia 6100 or ATI 700 or higher card on the game site. I have > been > looking for these cards on line and in store but been too suceessful. Are > these card numbers old or there newer numbers? What should I look for? > Lokking to spend under $200-$250. Looking on the Nividia & ATI sites do > not > give any understandable road maps. Any help or leads would be helpful. be more than adiquate to run Halo 2. Thank GOD you listed your computer model, THANK YOU! According to: http://h10025.www1.hp.com/ewfrf/wc/d...s=2093&lang=en Your system has 1 Gig of RAM running at DDR2/333Mhz or PC2-4200 speed Your motherboard uses the Intel 80945 chipset with integrated graphics. 250gb hard drive, dvd burner, etc. This system, as is, should be able to run Halo 2. Your system is scoring a 3.0 because of Gaming Graphics rating. My Dell at the office gets the same rating. This isn't necessarily a bad thing because your CPU, RAM, HD, and basic GRAPHICS speeds are fast enough to run teh haloz. If you still want to get a new graphics card, I would look into getting an NVidia 8600, or 8800 if you can afford it. If you want to buy an ATi Card, the ATi Radeon HD 2600 or HD 2900 is what you might want to look into. If you want to spend less, and don't care about DirectX 10 functions (Halo 2 does NOT use DirectX 10), the nVidia 7800 or 7900 cards are getting affordable, and are fast cards. The ATi x1650, x1800, x1900, or x1950 are all good choices. It all comes down to price. How much do you want to spend just to play Halo. I would not go any lower than that, your Intel Graphics card, as I said earlier, will run Halo 2! It will run slow, but it'll work. If Halo 2 is not running on your system, you should fix it before you go installing a new video card into your computer. -A. |
| | Re: Halo 2 on Vista Home premium system help Halo2 on Integrated Intel Graphics? If it even works (which 90% certain it won't, I'm a system builder) it will give you around 3-5 Frames Per Second. You need at least 30 frames per second to have any sort of smoothness to the game at all. I would honestly recommend getting at least the Radeon X1900, however I doubt your current PC could handle the HD2900 due to the heave power requirements. "Andy [YaYa]" <android8675@xxxxxx> wrote in message news:645793E4-5DDC-4CEB-8418-6F7AB67F81D7@xxxxxx Quote: > "DIGITALGOST20" <DIGITALGOST20@xxxxxx> wrote in message > news:684F8D37-1870-4AEF-ABA6-8AFE8722FA66@xxxxxx Quote: >> have I have a Compaq model 2180NX with 250 G HD and 3.3 DRAM with > 2 >> Ghz >> which I installed Halo 2 on. I have not installed a graphics card yet. >> The >> Vista system experience lowest rating is 3.0 on memory (video?) and the >> game >> will not work. I assume I need a graphics card. I have never used a >> graphics >> card. My system has 3 PCI & 1 PCIe slots empty. I have seen the notes >> about >> using a nvidia 6100 or ATI 700 or higher card on the game site. I have >> been >> looking for these cards on line and in store but been too suceessful. Are >> these card numbers old or there newer numbers? What should I look for? >> Lokking to spend under $200-$250. Looking on the Nividia & ATI sites do >> not >> give any understandable road maps. Any help or leads would be helpful. > The nVidia 6100 and the ATi x700 aren't too recent, anything recent should > be more than adiquate to run Halo 2. > > Thank GOD you listed your computer model, THANK YOU! > > According to: > http://h10025.www1.hp.com/ewfrf/wc/d...s=2093&lang=en > > Your system has 1 Gig of RAM running at DDR2/333Mhz or PC2-4200 speed > Your motherboard uses the Intel 80945 chipset with integrated graphics. > 250gb hard drive, dvd burner, etc. > > This system, as is, should be able to run Halo 2. > > Your system is scoring a 3.0 because of Gaming Graphics rating. My Dell at > the office gets the same rating. This isn't necessarily a bad thing > because your CPU, RAM, HD, and basic GRAPHICS speeds are fast enough to > run teh haloz. > > If you still want to get a new graphics card, I would look into getting an > NVidia 8600, or 8800 if you can afford it. If you want to buy an ATi Card, > the ATi Radeon HD 2600 or HD 2900 is what you might want to look into. > > If you want to spend less, and don't care about DirectX 10 functions (Halo > 2 does NOT use DirectX 10), the nVidia 7800 or 7900 cards are getting > affordable, and are fast cards. The ATi x1650, x1800, x1900, or x1950 are > all good choices. It all comes down to price. How much do you want to > spend just to play Halo. > > I would not go any lower than that, your Intel Graphics card, as I said > earlier, will run Halo 2! It will run slow, but it'll work. If Halo 2 is > not running on your system, you should fix it before you go installing a > new video card into your computer. > > -A. |
| Re: Vista Home Premium 64 bit Upgrade from Vista Home Basic 32 bitoperating system | Vista installation & setup | |||
| System restore on vista home premium sp1 | General Discussion | |||
| System crash during Vista Home Premium 64 installation | Vista installation & setup | |||
| What is vista home premium system builders | Vista General | |||
| System restore error on Vista home premium | Vista General | |||
