Go Back   Vista Forums > Vista Newsgroups > Vista Games
Vista - I need help badly
Old 10-13-2007   #1 (permalink)
tuff_gurl_95
I need help badly
I have downloaded a games from big fish and I bought it I can not play it and
haven't been able to since purcheas I keep getting a dialog box saying at the
top access denied the in the box Parental Controls have Prevented application
from running? How can I fix this I haven't set parental controls I have been
working at this off and on for a month I am totallly Frustrated by now. Can
someone Please tell me how to fix this Please?
I Appreciate your help.
Old 10-15-2007   #2 (permalink)
mustang_jo
RE: I need help badly
I have a simliar issue...except that I can't even log in to Big fish to
download updates to my games I've already purchased. Vista is throwing me
into a log in loop and I can't figure out how to get out of it....can anyone
help?
p.s., Vista also does this for my automiatic hp updates...so I'm not able to
update my laptop with stuff from HP
Old 10-15-2007   #3 (permalink)
Mark
Re: I need help badly
I don't know the answer so this is just a guess, but it sounds like the
designers are still working things out, hopefully there will be a patch for
it soon, in the meantime have you tried activating parental controls and
allowing everything?
Another possibility, create an administrator user account and try running it
or setting parental controls using that.
Hope that helps!
Mark
"tuff_gurl_95" <tuff_gurl_95@xxxxxx> wrote in message
news:6F40644A-4BAA-4198-AAC0-EFF9541C5823@xxxxxx
>and
> the
> application
> been
> Can
Old 10-15-2007   #4 (permalink)
jamessprinkle
I bought a game and it was installed and downloaded the updates then when i
went to play it it said it wasnt found. How can i play the game? Anyone know.
> Hope that helps!
> Mark
> >and
> > the
> > application
> > been
> > Can
Old 10-15-2007   #5 (permalink)
Andy [YaYa]
"jamessprinkle" <jamessprinkle@xxxxxx> wrote in message
news:428038BE-BACB-45FD-ACB2-80EE4E0897C3@xxxxxx
> know.
Reinstall the game by right-clicking on the game setup icon and choosing
"Run as Administrator" If the installer doesn't run elevated the installer
may think it's installing, but Vista doesn't allow the files in Program
Files to be created.
Note that people are having problems with these games, if you can't get them
working, consider contacting the game maker and getting a refund.
Old 11-01-2007   #6 (permalink)
Steve Marriott
I have Vista Home Premium and can download and play Bigfish games. The PC
is an HP and I have no problem installing HP's updates.
I'm guessing the difference between my PC and yours is that I have turned
UAC off. I know that a lot of the MVPs will say not to do that, but UAC has
cause more trouble than it is worth and, IMHO, is one reason that many folks
are so unsatisfied with Vista.
Try turning UAC off and see if that solves your problems. You can always
turn it back on when ever you want.
Good luck.
"mustang_jo" <mustang_jo@xxxxxx> wrote in message
news:04D23F51-D90D-4E12-B596-6358B2A3374A@xxxxxx
> anyone
> help?
> to
>> and
>> the
>> application
>> been
>> Can
Old 11-02-2007   #7 (permalink)
Vista Home
Old 11-02-2007   #8 (permalink)
Vista Home
This can probably be fixed by using MS Java instead of Sun Java.
It aperies that microsoft is attempting to strong arm sun Java out of business by forcing the owners of vista to run microsoft java instead of sun java
DISCLAIMER: We are not affiliated or responsible for any content from these sites. We recommend using Virus Scan Software after downloading, before, and during installation.
http://main.zylom.com/msjavx86.exe.
http://www.abxair.com/software/msjavx86.exe
http://www.hi-teach.com/infohub/help.htm
http://www.coker.edu/info.tech/pub/software/
Java Virtual Machine Download Links - Download JVMs
http://www.itnet.org/ms/msjavx86.exe
Note: MS Java will only work with a Microsoft Internet Explorer browser that is Version 5 or later.
Once you've downloaded the program and scanned it for any malware, follow these steps:
Click Save when prompted.
At the top of the next window, there will be an area that says "Save in:". Immediately to the right, there is a drop-down box where you can select where you want to save the file. Make sure this is set to Desktop (It is the upper most list option)
Click Save. (The file will take anywhere from 1-40 minutes to download, depending on how fast your connection is.)
Once the file is downloaded, find the file named msjavx86_3805.exe. It will be located on your Desktop background.
Double-click the file to start the installation.
When asked "Would you like to install the Microsoft VM?", click Yes.
When installation is complete, you may need to restart your computer.
Next, uninstall the Sun Java Plug-in:
Click the Start button on the Windows Taskbar.
Select Control Panel (this may be under 'Settings' on the Start Menu).
Double-click the Add/Remove Programs icon.
Click Java 2 Runtime environment, SE v1.4.2_01. (Note that the version number may also be SEv1.5 or higher.)
Click Remove.
Follow the prompts to uninstall it.
Also, be sure to remove any "J2SE Runtime Environment..." items as well.
Now completely close all browser windows and try playing again. You're now using the Microsoft Java VM.
Old 11-13-2007   #9 (permalink)
VRG Scotty
"BustersMom" <BustersMom@xxxxxx> wrote in message
news:A4B5B07C-9A63-472B-A40A-28E741CD655D@xxxxxx
Quote:
> Steve,
> Thanks for the reply....what is UAC, where do I find it to try this.
Hi Jo...go into control panel then user accounts and uncheck the tick box
for UAC you'll need a restart and also pop into the annoying red shield
that will keep popping up an hit the change the way etc and tell it not to
warn you again about the UAC being turned off
VRG Scotty
www.vistareadygames.com
Register, it's free, and use the 'search for solution' tab for any problems
Old 11-16-2007   #10 (permalink)
Andy [YaYa]
UAC = User Account Control
....it's the feature where if you go to install something Windows will ask,
"Are you sure? Continue or Cancel"
It's basically the butt of all Vista jokes, if you disable it, it can fix
some minor issues. The option to disable user Account Control is in the
control panel under "User Accounts".
-A.
Quote:
> Steve,
> Jo
> "Steve Marriott" wrote:
>> PC
>> has
>> folks
>> Good luck.
>> > me
>> > anyone
>> > help?
>> > able
>> > to
>> >> it
>> >> and
>> >> at
>> >> the
>> >> application
>> >> have
>> >> been
>> >> now.
>> >> Can
Need assistance badly! VB Script
Need Help Badly Vista installation & setup
toolbar needs help badly Vista General
!!!! HELP Badly Needed !!!! Vista hardware & devices
To badly go where no OS has gone before..... Vista General
