| | OT: Firefox -Using same bookmarks under... ....both my XP and Vista installs. Can I do that without moving a mountain? In my own little world, it seems akin to using the same Outlook .pst file, which you simply point to from both Oultlooks Guess its not that easy. If you can help, I'd appreciate |
| | Re: Firefox -Using same bookmarks under... Hi, Export your favorites into a bookmark.htm file and then import it into the firefox installation in the other systems. You are not going to be able to use a common folder between different installations. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org "DJ Bjorklund" <bjork57@hickorytech.net> wrote in message news:taqqa2phc6u8sj9b3o2g553d8rhft3eqa8@4ax.com... > ...both my XP and Vista installs. > Can I do that without moving a mountain? > > In my own little world, it seems akin to using the same Outlook .pst > file, which you simply point to from both Oultlooks > > Guess its not that easy. If you can help, I'd appreciate |
| | Re: Firefox -Using same bookmarks under... Yeah, comes right down to it, the "2 for 1" isn't really needed anyway. Thanks Rick On Thu, 6 Jul 2006 19:02:08 -0400, "Rick Rogers" <rick@mvps.org> wrote: >Hi, > >Export your favorites into a bookmark.htm file and then import it into the >firefox installation in the other systems. You are not going to be able to >use a common folder between different installations. |
| | Re: Firefox -Using same bookmarks under... Post your question in a Firefox newsgroup please. |
| backing up Firefox settings/bookmarks | Browsers & Mail | |||
| Firefox 2 dead bookmarks? | Software | |||
| RE: Putting Firefox Bookmarks on the Start Menu instead of Favorites? | Vista General | |||
| Re: Putting Firefox Bookmarks on the Start Menu instead of Favorites? | Vista General | |||
| Firefox bookmarks? | Vista General | |||
